 Northeast Ohio
 | Does anyone care to share their settings for the VFCIII and their Green/Blue settings?  Mine came from Lloydz at 6.5 (even though the manual said it would be at 0).  I lowered to 4 and have pop.  Going to raise it up, but don't want adverse affects on mileage.
 John
 Columbia,MO
 | Just installed my VFC III and I have the Lloyds intake and Cycle Dragon Pipes. Not sure what to set where either. Anyone have a suggestion? |
 Northeast Ohio
 | Sent you a PM with info. |
 Valdosta, GA
 | I've foudnt hat mine works best with all of the delay settings turned all the way down.
 | Lloyd has just posted an entry in his blog about popping and stalling. Link is on the frontpage, top right corner. |
 Arkansas
 | mike s, I thought that "all the way down" on the VFC is OFF. I can only assume that you have different info?
 Valdosta, GA
 | Nope. no different info. I've turned OFF all three of my delay settings. The stalling issue has all but gone away (still some periodic hesitation) and I pop FAR less then before.
