Posts: 3204 Memphis | I found these online and am thinking about mounting them instead of cutting away at the "swoosh" (great idea if I lived in the desert or Florida) or adding the Victory deflectors. The face of the swoosh is 3" across and these vents are 2 1/2" diameter. Once mounted, the chrome ring would probably take up the whole 3". I'd probably have to cut away some of the black inlet to get clearance on the backside. They'd mount about halfway up the swoosh in order to clear the master cylinder. I could block them off in the wintertime. I'm leaning towards the spoke design (called sillouette on the website) because it looks like a Ness wheel. Any thoughts or suggestions? http://store.summitracing.com/egnsearch.asp?N=700+115+%2D164780&D=%2D164780
| those are real nice looking vents, i had thought about doing something like this but cut mine and i am very happy with the results. these vents will look great i just dont know if it will be enough air volume. tom |
Posts: 3204 Memphis | tom, Thanks for commenting. I really like your mod, it's just too permanent of a solution for where I live. I was really glad to see you could pull it off with just hand tools. I know I would miss the cutaway piece in the dead of winter. It seems like the heat is caused by a pocket of dead air right next to the engine. (Perfect for 35 degree days.) If I could just get some air flowing through there to break up that bubble it would make a big difference. Since those vents swivel, even a small stream of air on the hottest spot would help. I would get one for the left side to match but would cut almost all of the back part off because of clearance issues with the horn mount bracket and frame. Making black plugs for the backside (complete with "Remove before flight" streamers) would be easy. The cheaper black vent with the big slots would probably be the most practical but I'd have go for the silouette model for style points.
Edited by SongFan 2008-08-09 1:30 PM
| your vents look great and maybe it will be enough to break the air bubble, it will look very custom. im not worried about rain and cold since your leg is so far back behind all the front fairing the wind on my leg wont include rain since it is so far back. also im used to cross country on a harley with no fairing at all, just ride real fast ...been doing it for 40 years without i just dont like heat so its worth it for me. do your custom vents it sounds great ,send me photos when you get it done, when next week....tom |
Posts: 1632 Jasper, MO | I've been thinking about installing some kind of vents also. They were features on some of the other, older touring bike designs. The older Yamaha Ventures had them and so did my old Kawasaki Voyager XII. They worked well on the Kawasaki. They were ducted from under the front of the fairing and could be opened or closed while riding. That old Kawasaki was a pretty darn good touring bike. Nowhere nearly as comfortable as my Vision, but it did have a lot of neat features and could run 12.90's with only a 1200cc engine, which is about what the GL1800's are capable of. Anyway,I'm wondering if there might be a way to adapt some sort of closable vents to the Vision.
Ronnie |
