| I've got a 2013 Vision Tourer and I just spoke with my dealer and they told me that there are NO lowering kits for the Vision and that any kit installed would invalidate my warranty. So I called Victory and they said the same thing...
Didn't the Nes model come with the bike lowered and that was sold new off most Victory lots?
I know there are lowering kits from aftermarket places but not sure I want to throw away my warranty and I definitely don't want to do the work myself.
Thanks!!! |
Posts: 416 Prairie City, IA United States | I think the Ness Vision is lower due to the seat being cut lower. I don't know what you wear for shoes but you might try a taller heel boot to gain some height. |
| The 8-Ball and Ness use the same length shock as the Tour but a much softer spring. The link pivot is drilled different which lowers the bike, shortens the stroke and necessitates the softer spring. The link itself is the same length as the Tour. The front has shorter and softer springs, different cartridge valving and no spacers. The end result is 1" lower at both ends. In addition to that the seat is also an inch lower. I did a bunch of research into this is why I happen to know :-) BTW, anybody who wants to improve the ride and primarily runs without the trunk and needs a new shock get the one for the Cross Country. It has a softer spring and improves the ride on the Vision. The stock Vision spring compensates for the trunk which makes it a bit stiff without it even with no air.
Marc |
Posts: 8144 New Bohemia, VA | Marc, I almost got the CC shock but decided not too when I found a stock one from an '08. Good shock and stiffer than what my orginial was. I think I had a bad shock, or went bad early on. I've hit some holes that the old shock always bottomed out on. As far as lowering, I've given it thought, using all the right stuff, but didn't want to have to always watch because of it being lowered. To do it right, you have to change out the inside bags, else it will get you one day. I somehow understand why Victory back away from it. And remember, the change has to be relateed to the failure before the warranty is void for that issue. If you're engine blows up, that should be covered, even though you lowered it, unless you hit a bump that the stock height would have missed it, and you knock out your crank. |
Posts: 1066 Peru, IN | Greywolfe64 - 2014-05-12 12:41 PM I've got a 2013 Vision Tourer and I just spoke with my dealer and they told me that there are NO lowering kits for the Vision... Of course there are lowering kits for the Vision. HMD and Witchdoctors both carry them. You can get 1", 1.5", 2" and 3". They recommend the saddlebag insert for anything more than 1". They also have 1" lowering kits for the front (which I think is just spacers and longer bolts for the handlebars...you just loosen up the triple tree bolts and slide the forks up an inch). |
| varyder - 2014-05-12 12:44 PM
If you found a used 8-Ball or Ness shock which has the proper softer spring and just bought the 8-Ball/Ness pivot you'd get the lowered effect without any chance of damaging the bags. It would just be the factory lowered setup including reduced stroke. Its amazing how many of those shocks show up on eBay. I even played around with changing out the spring alone but forget it. They made it damn near impossible to get the spring out without sacrificing one of the components that you can't buy.
I forgot to mention that with the proper pivot the bike doesn't compress any lower than the Tour does. It just starts out 1" lower but ends up at the same place due to the shorten stroke so you don't have to worry about hitting stuff as a result of bumps.
Marc
Edited by marcparnes 2014-05-12 4:08 PM
Posts: 161 Albuquerque NM | The Magnuson Moss act of 1975 says if you modify your vehicle while it is covered under warranty, the parts modified and ancillary damaged may not be covered but it cannot void an entire warranty. So if you decide to lower your vision, and later in life your dealer says they won't fix your radio or some other unrelated component because you "voided" your warranty by lowering your bike. You can let them know in no uncertain terms that they are not allowed to do that by law.
http://en.wikipedia.org/wiki/Magnuson?Moss_Warranty_Act |
| I think your wrong on the Ness shock being softer. You would bottom out more and they do tell you same air pressure for riders weight.
The shock would be shorter with a stiffer weight ratio.
If you look on the Vic's parts list they have the same part number for both links.
Inner saddle bags are the same and so is the kick stand
stock shock p/n 1542903
Ness shock p/n 1542904
link rod p/n 2877612 for both models |
| johnnyvision - 2014-05-12 4:59 PM
Nope, you are wrong John. The spring is softer because the ratio and rise is faster. The shock is exactly the same length with exactly the same stroke. The link is the same as I said but the pivot is drilled differently which allows for the lowering and shorter stroke. If you look up the shocks you will see that the spring is rated 105 N/MM on the Tour and 50 N/MM on the lower version. Believe it.
Marc |
Posts: 155 Victoria Tx, TX United States | Corpus Christi dealer lowered mine 1.5". Witchdoctor has the lower price. Mine I bought from dealer since they where installing it. JUST MAKE SURE you re adjust your headlamps to compensate for the rear lowering. |
| Thanks for all the replies. I guess I'll just have to go to another dealer to get it installed. Because quite frankly the seat height is more of an issue that I thought it would be when I bought the bike. I sat on all 3 of the major touring bikes (Electraglide, Goldwing and Vision) and had the same issue on all three. The vision was the shortest of the three and I never figured it would be a major issue with the dealer to get installed.
Thanks gr8punkin I'll keep that in mind.
| So let me ask... how low can I go before having to cut out the saddlebags and replace the kickstand?
I've heard 1" is not a problem with either and that only the 2" and more do you have to cut out the saddlebags and replace the kickstand? |
Posts: 161 Albuquerque NM | No problem Greywolfe, I lowered my dads bike by modifying the rear link and sliding the tubes up the triple trees. So approximately 1" rear and 3/4" front, I suspect he's seeing some rubbing in the saddle bag when the air in the shock has leaked out. His bike stands up a lot straighter on the stand now than it did before, which is a mixed blessing. I don't think it's as stable now, but it's much easier for him to pick up. |
Posts: 8144 New Bohemia, VA | with 26.5 inch seat height and narrow straddle, the Vision is more than adequate for my 30 inch inseam. A friend of mine had bought a new Harley and was waiting for them to lower it for him, he's got a 28 inch inseam. I told him to hop on my Vision and he was amazed his feet were planted on the ground. Made him think twice about Victory. |
| gr8punkin - 2014-05-16 4:02 PM No problem Greywolfe, I lowered my dads bike by modifying the rear link and sliding the tubes up the triple trees. So approximately 1" rear and 3/4" front, I suspect he's seeing some rubbing in the saddle bag when the air in the shock has leaked out. His bike stands up a lot straighter on the stand now than it did before, which is a mixed blessing. I don't think it's as stable now, but it's much easier for him to pick up. sooner or later it will tip over. A semi going by coudl cause it. get a shorter one |
| varyder I have a 28" inseam and I'm on my tip toes when stopped. Don't get me wrong there was not another tourer (stock) that I could touch the ground on either. |
Posts: 161 Albuquerque NM | It's remained standing when my six year ran into it at full steam, so I'm sure the gust from a passing semi won't knock it over. I talked to my dad about it when we first lowered the bike, and he wanted to have it stand a little straighter, since his left knee is so bad after injuring it as a kid (wrecked his Cushman eagle). He'd rather have to watch where he parks than strain his knee.
If it were my ride I would have changed that stand already, but I'm not patient enough to search out the flat parking spot. |
Posts: 42 Vacaville, CA United States | I bought a 2013 Victory Vision new and the dealership lowered it 1". Also, all of their demos are lowered 1".
Daveg53
2013 Victory Vision Tour
Lloydz timing gear
Lloyds VFC III
Witchdoctor monster baffled pipes |
Posts: 16 Madison, WV | Reviving this for a question guys - I have an 08 comfort tour, if by chance I come across used shock/pivot/link and seat off of Ness/8Ball versions can I install both and lower my seat height by 2"? No trouble to saddle bags? Will these parts interchange? Eventually I will lower my bike and looking at options. I ride with a passenger almost all the time and not sure I want to run 60 lbs or higher air in shock to try not to crack saddle bags. Reading different posts people who just lowered 1" still cracked their bags. I am aware of the Ness bag inserts so another way looks to be to get a 2" lowering link and the bag inserts. Just curious about the Ness/8Ball option. Thanks for any input. |
Posts: 25 Hastings, MN United States | Witchdoctors lists several kits for lowering the Vision on their site: http://www.hmd520.com/?s=vision+lowering&post_type=product . You might want to look there and talk to them about it. |
| from what I understand a 1/2 inch equals a inch. So I cut a inch out of my link. Si that means I lowered it 2 inches.
with just me on it I have bottomed out twice. Putting a crack in right hand inner bag. Covered it up with black silicone to keep water out.
I'm 230 and ride with 40 psi in shock.
Whatever you have for air in shock now add ten or fifteen pounds you'll see bike only goes up about a 1/4 inch.
start out with more than you think and take some out till you find a good spot. Rail Road tracks or crossing are the worst.
ask sell how long rod is. Stock is 12 inches
http://www.ebay.com/itm/11-Polaris-Victory-106-touring-Vision-8-Bal...
Posts: 16 Madison, WV | I had saw that link on ebay, same guy has the 8Ball shock. That is what got me thinking about using those parts to maybe keep from needing to modify the saddle bags. HMD has this on their site for the 2-3" drop, "NOTE: Lack of improper air pressure in the shock, could result in damage to the link. We recommend that you keep 30-35 psi. (for one rider), and 60-65 (for two riders)" Even with modified bags you need to watch pressure I guess. Maybe I will just get a taller boot :P
Posts: 70 Indianapolis, IN United States | For those that are looking at the Ness or 8Ball Seat to help lower for inseam issues - I have a 2012 Ness. The one complaint I have (really my wife has) is that I sit so much lower than she does. I think the seats are only scooped out for the "driver" not the passenger. She seems way above me when we ride which means she catches a ton more wind than I do. Just saying... |
Posts: 16 Madison, WV | money going other places at the moment, ha. If by chance a taller person wants the opposite I could trade my touring seat for a lowered one. |
| wait till you bottom out and crack the inner bag. Don't spend money you don't need to |
Posts: 16 Madison, WV | Ok, so I got HMD520's 2/3" slam package on ebay for $200 to the house. About $625 package on their website. I installed everything except the 1" lowering kit for the front end. Set it up for the 2" drop, installed the link, kickstand, skid plate and saddle bag inners. Turned out to be a decent little undertaking. Not sure if I can figure out how to post a couple of pics but I will try. Need to ride a little more to see if I think it was worth the effort, better footing was needed but hopefully not at the cost of the comfy ride. It recommends 60-65 psi with passenger. If we don't like it I will just put the original link back on and get a tall pair of boots or something :P. I will let you guys know how it goes.
 (IMG_1018.jpg)
 (IMG_1019.jpg)
 (IMG_1015.jpg)
 (IMG_1032.jpg)
Posts: 1308 Sand Rock, AL United States | Man! That does look like a lot of work. Good job! Keep us posted.  |
Posts: 70 Indianapolis, IN United States | How much does it lower it? I love my Ness which is lowered from the Factory. A normal Vision is too tall for me. Handling wise, the Ness is still the best handling bike I've ever ridden - but I've not spent much time on a stock height Vision to compare. |
| think you went overboard sorry to say. I pulled my rear wheel put in a 2 inch lowering link and that's it.
Be for I found I needed 40 pounds of air in shock I cracked the inside of my bags. I used black silicone to fix crack. No water leak now.
I lowered the front end and that stopped the wind buffeting when behind semis. You should do it very simple.
Don't for get to adjust the headlight |
Posts: 16 Madison, WV | This lowered it 2" from stock jdr, which I think puts it at the seat height of your Ness. The link I got can go to 3" but currently just trying 2". You're probably right johnnyv, just figured since that was a pretty decent deal on the kit I would go that way but it was a lot of work. Along with the kit was front end lowering hardware too, I wasnt planning on using it right now but you say it helps with the wind buffet? I didnt know it would do that, more likely to install it now. |
| Let us know if you think it help with the wind buffeting when you lower the front end. What exactly are the details of the front end lowering ? |
Posts: 16 Madison, WV | Haven't got into yet but it looks like you add spacers to raise the handlebars a bit so that you can loosen the triple trees and slide the forks up about 1". Those who have done it can let us know if I am off on that. I'll let you know if I notice anything afterwards. |
| it really help when you're stuck behind semis.
pull the dash panel. now unbolt handlebars put spacers in place. Bolt bars down.
Then loosen the pinch bolts on the fork tubes. 6mm allen I believe. Now tubes will slide up. you're done.
 (6736.jpg)
Posts: 16 Madison, WV | Lowered to front now, I'll try to attach photo of finished product. Quite a bit more stability at stop lights, moving around in parking lots. Happy enough with the change. Dragged the floorboard for the first time, it was a pretty decent curve though so nothing i am worried about. a little of a pain getting to the top tree clamp bolts but nothing to bad, forks slid easily once things were loosened up.
 (Lowered.jpg)
| VWHills: Where did you get the Spacers & what did they cost? |
Posts: 60 Racine, WI United States | Nice job, WVHills. Bike looks good sitting at that level. I didn't see if you did the inner bag mods or not, and if you did, exactly how hard was it to do. Just looks from what I've seen on a couple that used the kits, that it was a little time involved, not really that hard. Thanks. |
Posts: 16 Madison, WV | wingit - the bolts and spacers were part of the lowering kit from HMD520. Looks like $69 on their website. The bolts could be picked up at about any hardware store, might need to look a littler more for correct spacers or see what others have used if they didn't buy a kit.
huts - thanks. I did the inner bag mods, again, part of the kit. You have the idea though, not really hard but time consuming. I removed the bags. Just put the piece inside the bag, then trace and cut. I used a dremel type cutter. Johhnyvision said he did not cut the bags and is doing ok, just watch air pressure in shock. I almost always am riding with passenger so I went ahead and done the inserts. |
Posts: 1308 Sand Rock, AL United States | Thanks for the info WVHills. Wow, it still looks like winter where you are. Everything is full plumage in Bama. Flowers, butterflies, already seen lightening bugs even.  |
