Posts: 53 Shelbyville, IL United States | Any one run a top filter with a stage 1 down load and no fuel controller ? Does it run ok? |
Posts: 3773 Pittsburgh, PA | those downloads arent that good at all.. why? because in order for Victory to be able to create and sell those downloads, they have to Meet E.P.A. regs.. so what does that mean? They have to be lean...(meet a target A/F ratio) or at least leaner than what you really require in order to run properly. When i had my 08 i got the download with my S1L1 setup.. in less than a year a i purchased a power commander 5, and then my scooter really run better! so if that download is lean when using JUST a performance front filter, i would guess to say it would run even More lean if you have a top filter that allows even More air into your motor... |
| Stage 1 will increase your fuel by 1% and it will add about 2% to your timing. For what they charge a power commander would be a bigger befit for sure.
I have the top filter and didn't see much if any change. Except you here the motor sucking more. No flash and bike runs great.
Your best bet would be buy a Lloydz timing wheel and hang on. $162 bucks. |
Posts: 53 Shelbyville, IL United States | Already have timing wheel and Stage 1 on the bike. Getting ready to put ness bigg honkers on next week. I will wait to get top filter till I get cams a pcv put on this fall. |
Posts: 1 Detroit, MI | OK so the Vision does have 2 filters????????? |
Posts: 1365 Central Maryland | roscoerf - 2014-05-17 6:09 PM
OK so the Vision does have 2 filters?????????Yes it does (meaning it can) but you have to remove the top plate in the frame under the radio, and add the second filter yourself.
Edited by willtill 2014-05-17 5:45 PM
Posts: 3773 Pittsburgh, PA | roscoerf - 2014-05-17 5:09 PM
1) http://www.cruisercustomizing.com/arlen-ness-twin-sucker-front-perf...
2) http://www.cruisercustomizing.com/twin-sucker-top-performance-filte...
Posts: 53 Shelbyville, IL United States | Bought power commander and top filter. Going to The VIC shop june 9th to have it tuned. I would lovre to get cams but momma said no lol. Maybe next year. |
