Posts: 1340 Gainesville Fl Home of the Gators | Just read the entire service bulletin, and this should be quick, and easy. Vic is sending a digital dial indicator with a hard mount fixture. If the engine fails the test the solution is super simple. Remove the primary, and add a diamond coated thrust space between the crank, and flywheel. This will properly space the crank, and thrust service. The whole thing should take a couple of hours, and includes oil, and all pre Loctite coated bolts. |
Posts: 1066 Peru, IN | Nice of you to let us know Kevin! |
Posts: 180 Georgia On My Mind.... United States | Yippie!
Edited by Pops 2014-05-07 9:09 PM
 (clap.jpg)
Posts: 1340 Gainesville Fl Home of the Gators | Pops that was awesome
Posts: 178 LaGrange, GA | Are we not worried about the metallic debris that will result? Expected to be such a tiny amount the filter will quickly pick it up? |
Posts: 1340 Gainesville Fl Home of the Gators | There is no cutting or grinding with this repair, and if you need it, an oil change will be provided with it.
The thrust surface in the primary case was not cut properly, and there is a CHANCE the flywheel could rub the case. The shim goes between the flywheel, and crank; to space the flywheel out a few thousands. The same exact type of shimming can be found in auto manufactures forever. I set up end play for the crank with shims on my air cooled VWs, and they have been doing that since the 30's |
Posts: 8144 New Bohemia, VA | No big deal for sure. Kudos to Victory for taking care of this quickly on the limited number of bikes affected. I was looking up motorcycle recalls and got inidated with ones from Harley, Ducati, Triumph, and BMW for recent years. Wow! |
Posts: 752 Broken Arrow, OK | and kudos to Kevin. Thanks for taking the time. |
Posts: 178 LaGrange, GA | kevinx - 2014-05-09 10:06 AM
Ohhh, I gotcha - I thought the diamond coated spacer was intended to grind and self-clearance, like a diamond-coated sharpening stone. So it's really just diamond coated so it will be really hard and permanent - I get it. That sounds a lot better than what my mind had. |
Posts: 180 Georgia On My Mind.... United States | kevinx - 2014-05-08 11:36 AM
 (please capt.jpg)
please capt.jpg (18KB - 0 downloads)
