| The power outlet on my 2013 vision working Monday when I started out for a ride., I didn't have time to play around with it but I did take a look at it tonight and found the ground cable had fallen off the outlet. Where the outlet mounts is all plastic so I quickly realized there had to be a ground cable somewhere up there and sure enough there was. I had to remove the wedge and manned to get my hand up there and found it. I plugged it into the power outlet and all is working agian. I hope this helps anyone who has a problem with the power outlet in their glove box on their vision.
MrBill 65
2013 goldmist Victory Vision. |
| So you pluged the ground into power? Maybe you should look at what you said |
Posts: 3773 Pittsburgh, PA | johnnyvision - 2014-04-23 6:49 PM
where does it say this?? |
Posts: 1632 Jasper, MO | johnnyvision - 2014-04-23 6:49 PM
The power outlet has TWO connections, since it is mounted into a plastic body. One for +12 V and the other for - ground. He reconnected the - ground into the power outlet--NOT the +12 V connection.
Ronnie |
Posts: 3773 Pittsburgh, PA | rdbudd - 2014-04-23 11:18 PM
+1 thats what i read as well |
| Arkainzeye - 2014-04-24 5:53 AM rdbudd - 2014-04-23 11:18 PM johnnyvision - 2014-04-23 6:49 PM So you pluged the ground into power? Maybe you should look at what you said The power outlet has TWO connections, since it is mounted into a plastic body. One for +12 V and the other for - ground. He reconnected the - ground into the power outlet--NOT the +12 V connection. Ronnie +1 thats what i read as well Same here. |
| mrbill65 - 2014-04-22 8:36 PM The power outlet on my 2013 vision working Monday when I started out for a ride., I didn't have time to play around with it but I did take a look at it tonight and found the ground cable had fallen off the outlet. Where the outlet mounts is all plastic so I quickly realized there had to be a ground cable somewhere up there and sure enough there was. I had to remove the wedge and manned to get my hand up there and found it. I plugged it into the power outlet and all is working agian. I hope this helps anyone who has a problem with the power outlet in their glove box on their vision. MrBill 65 2013 goldmist Victory Vision. this is the post |
Posts: 3773 Pittsburgh, PA | johnnyvision - 2014-04-24 6:14 PM
the 2nd highlighted sentence/phrase. what is the first word AFTER the last word that is highlighted.. that is what i read. and that it what i understood that he did.. he saw a wire (loose/hanging) and he Reconnected it to the power OUTLET.. and nothing more..
Edited by Arkainzeye 2014-04-24 6:44 PM
Posts: 92 Moncks Corner, SC United States | Really? |
Posts: 215 W'ford Tx | My dad can beat up your dad. |
| All I was trying to do was give other vision owners a heads if they had a problem with the power outlet in the glove box. not start a discussion on my writing skills or lack there of. LOL.
Mrbill65
2013 Goldmist Vision |
Posts: 1632 Jasper, MO | mrbill65 - 2014-04-25 3:24 PM
Mrbill65
Thanks for the heads up.
Your writing skills are fine.
Ronnie |
Posts: 3773 Pittsburgh, PA | mrbill65 - 2014-04-25 3:24 PM
Mrbill65
exactly !! and you did a great job of it.. seriously.. i appreciate your efforts... |
| Typical jonneyvision guys. Movin on |
Posts: 8144 New Bohemia, VA | The Vision is plastic? |
Posts: 880 Orlando, FL | .
 (Cat and popcorn.jpg)
Cat and popcorn.jpg (30KB - 1 downloads)
