Posts: 36 Stoughton, WI | I keep seeing posts about upper and lower air filters. I can only find one in my service manual for the 2011 vision it is beneath the front lights. Where is the lower filter and how do you get to it. Thanks |
Posts: 366 Albuquerque, NM | It's mounting location is on the alum. frame under the key/radio console. Here's a link to lloyd's installation sheet.
http://www.lloydz.com/downloads/VisionSecondaryIntakePlateInstructi... |
Posts: 2300 Georgia, west of Atlanta | The second filter goes just above the throttle bodies. It's a drop in filter that takes the place of the throttle body inspection plate. If you opt for the lloydz or Arlen ness drop in filter, you'll never have to replace the front filter again because 90%of the air going through the throttle bodies will come right from above . |
Posts: 36 Stoughton, WI | Thanks, got to get this filter and the adjustable timing gear. |
| bad photo but here under radio
 (002.JPG)
Posts: 2300 Georgia, west of Atlanta | It's very easy to change out. My 2013 Has a top filter, PC-5, S1L2's and a Kyle Crandal dyno tune. Made 97.85 HP and 113 ft lbs Tq. |
Posts: 1066 Peru, IN | If you get a top filter (it's NOT stock), you'll probably need an aftermarket fuel processor (NOT a factory Stage 1 download...waste of money). |
