Few Exhaust Questions
southjerseyrider
Posted 2014-04-19 2:26 PM (#154388)
Subject: Few Exhaust Questions
Vineland, NJ United States
Thinking about going from Level 1 exhaust back to OEM exhaust.  Can I retain the Gatlin tips?  Will i have to adjust my VFC III? What parts do I actually need to do that?  just mufflers, do I use same heat shields or do OEM use different heat shields?  Any suggestions or comments appreciated.
kevinx
Posted 2014-04-19 4:00 PM (#154389 - in reply to #154388)
Subject: Re: Few Exhaust Questions
Yes you can still run the gatlin tips, yes you will swap out the heat shields, and yes you will have to reduce the fuel slightly in the VFC
southjerseyrider
Posted 2014-04-19 4:24 PM (#154390 - in reply to #154389)
thanks!  do you think I will notice a big difference in power?
Posted 2014-04-19 4:54 PM (#154393 - in reply to #154388)
stock is no as good as the S1
kevinx
Posted 2014-04-19 7:36 PM (#154396 - in reply to #154388)
Actually there is little performance difference between stock and S1L1. Stock makes a tad more torque, S1L1 makes a tad more HP
el spanky
Posted 2014-04-19 8:27 PM (#154397 - in reply to #154388)
Victoria Tx, TX United States
When I went from stock to stage 1. I felt a big difference.
Posted 2014-04-20 8:57 AM (#154418 - in reply to #154397)
el spanky - 2014-04-19 8:27 PM
No doubt, BUT I'll bet you also had the ECU reflashed to the Stage 1 map at the same time, which is where the performance increase actually came from. The mufflers just don't make that much difference by themselves.
The same or better performance could be had with the stock exhaust and a fuel controller and top filter.
Pretty much the same Stage 1 performance can be had with the Stage 1 map, intake, and the stock exhaust.
The fuel and timing control, along with more intake capacity (top filter) is where the performance actually comes from. The stock exhaust isn't restrictive on a 106. It's just quiet.
Don't think so? Check out Lloydz dyno page and the 116 inch Vision. He got 137.39 horsepower and 133.53 torque on a 116 build running the STOCK exhaust. The stock or Stage 1 mufflers aren't going to hold a little 106 back, and other mufflers aren't going to make all that much difference in performance either.
Edited by rdbudd 2014-04-20 9:01 AM
Posted 2014-04-20 5:57 PM (#154425 - in reply to #154388)
this is stock baffles. By the way I have stock mufflers for sale
(6b66d8aff141944f2b8c8dcdf6535207.jpg)
Attachments 6b66d8aff141944f2b8c8dcdf6535207.jpg (76KB - 0 downloads)
el spanky
Posted 2014-04-20 6:21 PM (#154429 - in reply to #154418)
Yes I had the reflash. Just wanted the sound and some better performance... V twins... If I want real HP I'll ride my friends Turbo Busa!!
Posted 2014-04-21 12:00 PM (#155449 - in reply to #154429)
el spanky - 2014-04-20 6:21 PM
That'll do it!
I've had fast bikes and drag raced them on street and strip for many years.
I've also found that is just as much, and maybe even more fun riding slow bikes fast, and much more fun than riding fast bikes across the country slowly.
