Posts: 38 LaFayette, GA United States | All my other bikes had an LED liscense frame with a brake light modulator installed. I've always used the ones from Signal Dynamics in Florida without any problem. I'm a firm believer in being seen and heard. The one pictured is on my Suzuki S50. I want to get the same setup for my 2012 XR, but I've heard that messing around too much with the lighting circuits can screw up the cruise control.
Also, I just ordered the pulsing headlight modulator. I've had one on my last four bikes. Has anyone done a mod like either of these to your Victory? Did it cause any problems? Any advice will be apreciated.
Edited by Zig-Zag 2014-04-08 2:09 PM
 (LED Plate.jpg)
LED Plate.jpg (38KB - 0 downloads)
Posts: 1365 Central Maryland | I have the Kisan headlight modulators on my 2011 Vision. Other than the rear of the headlamps to be a bitch to work with (little room for fingers/hands) the modulators cause no issues. |
Posts: 161 Albuquerque NM | I have the Back Off modulator and license plate ring on my vision, and it caused no issues. I just tapped into the brake light and running light wires under the seat and followed directions.
Posts: 38 LaFayette, GA United States | Thanks for the encouraging words, I'm installing the headlight modulator tomorrow. The Back Off Liscense frame/module has to wait a while. |
Posts: 752 Broken Arrow, OK | I have that same frame from Signal Dynamics. Took it off my Yamaha and put it on the trailer we pull w/ the Vision.
I understand wanting to use it on the bike, it's a nice product. |
Posts: 1229 Rancho Cucamonga, CA | I had to add a 25ohm resistor w/ heat sink so the cruise control would still be able to find ground. I think a 50 or 100ohm would have worked just as well. It just had to have a constant ground that the Back-Off modulator interrupted. I don't know if the X bikes have the same issue since they use LED brake lights. LEDs have a built in ground issue that would have already been corrected for. PM me if you run into any problems.
Edited by Nozzledog 2014-04-11 1:49 AM
