Posts: 341 West Salem, WI United States | I'm looking for information on how to tap into the bike stereo's output. I would like to use the option to turn off the external speakers and then plug a new 1/8" stereo cable into the Sena SR10 module so I can listen on a set of Sena headsets but still control volume etc on the bikes controls. 2013 Vision |
| http://www.vision-riders.com/bb/forums/thread-view.asp?tid=10076&po...
I also bought the parts to build 3 of them. One of the suppliers had a minimum order. I have in my hand right now the plug and 3 of the crimp on connectors. I would be happy to donate them. All you will need is the stereo cable to cut up for the plug.
 (20140330_222839 (Medium).jpg)
20140330_222839 (Medium).jpg (56KB - 0 downloads)
Posts: 341 West Salem, WI United States | Thanks, I PM'd you. Does this plug then plug into the stereo itself? |
Posts: 3773 Pittsburgh, PA | i thoguht there was a option with in the radios on screen options to turn off the speakers? |
Posts: 341 West Salem, WI United States | Arkainzeye - 2014-03-31 7:50 AM i thoguht there was a option with in the radios on screen options to turn off the speakers? There is, but I think you then would need to have the CB/XM kit installed to hear through the headsets. |
Posts: 573 Central Illinois | If you install that plug and run it to a bluetooth transmitter using these instructions, the options to use it for your headset stereo is wide open.
http://www.vision-riders.com/bb/forums/thread-view.asp?tid=10099&po...
The install bypasses the Vic wiring harness completely. |
