Lighted Badge burnout repair.
JS5Owner
Posted 2014-03-21 12:18 PM (#152512)
Subject: Lighted Badge burnout repair.
My 2009 Ness had the left side lit badge burn out. I knew from reading here (and elsewhere) that the badge is lit by an LED panel that was created by Lumex just for Polaris to put on the Vision. Normally these LED panels should last a long, long time.
I popped off the glued-on chrome bezel (via the weep hole on the bottom) which, BTW, came off fairly easy. This revealed the LED panel.
20140319_112015
The panel is glued in by what looks like silicone glue drops around the inside.  I carefully detatched these points and removed the panel.
Next I excavated some of the plastic inside the shell so that I could then put some strip LEDs inside.
20140319_132132
20140319_132111
Here are the LED strips attached to the inside of the shell
20140319_134752
As you can see I installed some blue LEDs!  Here is the finished look.  I reglued the badge on via epoxy.
20140319_134808 20140319_212840
One final observation.  I believe the orignal panel failed due to water entering in between the logo and panel and shorting it out.  I think this is the case as there was evidence of wetness on the inside of the logo.  I'm going to seal off my other light where the chrome bezel meets the logo.
My blue LED's show the logo really nice in the day!
Edited by JS5Owner 2014-03-21 12:18 PM
lennyb
Posted 2014-03-21 4:52 PM (#152516 - in reply to #152512)
Subject: Re: Lighted Badge burnout repair.
Perry Hall, MD
Nice job. Thanks for the idea and pics.
Jimbo62
Posted 2014-03-21 8:47 PM (#152525 - in reply to #152512)
How much brighter is the new and improved side compared to the regular side?
JS5Owner
Posted 2014-03-22 12:24 AM (#152530 - in reply to #152525)
Jimbo62 - 2014-03-21 8:47 PM How much brighter is the new and improved side compared to the regular side?
Because it is blue, it is hard to say.  In my eyes it stands out more artistically... hense brighter.
Posted 2014-03-22 6:12 AM (#152539 - in reply to #152512)
i did that same thing in 2009 when my 2008 visions left badge burned out! its alot cheaper than buying a new set !!
okie vision
Posted 2014-03-22 1:57 PM (#152553 - in reply to #152512)
Broken Arrow, OK
Pulled over a few months ago and the right side badge was dangling by wires on my 2011. Glued it back on.
I can see a mod like this in my future. Thanks for posting, good job
Posted 2014-03-23 1:59 AM (#152568 - in reply to #152512)
What a great idea.! I had one replaced under extended warranty, but when that runs out, I would definitely do that before buying a new one.
Posted 2014-03-23 9:17 AM (#152575 - in reply to #152512)
before you glue it back together.. TEST IT. when i did mine years ago, i did it once and didnt like it and had to add MORE lights so try and get it to match the other side. also keep in mind "color" of the led you use..
Double Vision
Posted 2014-03-23 9:51 AM (#152576 - in reply to #152512)
Thanks for posting this!
Posted 2014-03-23 11:29 AM (#152585 - in reply to #152512)
You should put this write up in the Tech section.
Nice work
victoryvisiontour
Posted 2014-03-23 2:50 PM (#152595 - in reply to #152512)
Good info. Thanks for posting.
JS5Owner
Posted 2014-03-23 3:37 PM (#152598 - in reply to #152512)
I'm glad folks like the concept... I think if Ma Vic would have sealed the logo/lens to bezel we would see fewer failures. Water on electronics doesn't help them.
LA Victory Rider
Posted 2014-04-04 10:41 AM (#153969 - in reply to #152512)
Monrovia, Ca
Had my left side replaced last month under warranty. Now I know what to do next time
RedRider
Posted 2014-04-07 4:37 AM (#154044 - in reply to #152512)
Thanks. Nice write and pics.
Ploz58
Posted 2014-04-25 2:23 AM (#155602 - in reply to #152512)
Central Victoria, Australia
What type of LEDs did you use?
Nice and simple, I like the blue. Has anyone else tried another colour!:-)
JS5Owner
Posted 2014-04-30 9:55 AM (#155800 - in reply to #155602)
Ploz58 - 2014-04-25 2:23 AM What type of LEDs did you use? Nice and simple, I like the blue. Has anyone else tried another colour!:-)
I don't remember the brand.  I actually think I got them from China via eBay.  They were about 16" long but had the ability to cut the strip after 3 or 4 LEDs.  That is what I did.
Posted 2014-08-31 7:25 AM (#165696 - in reply to #152512)
the repair works but does NOT look anything like the other side. be ready for that, if this is something that is Important to youself.... i did this 5 years ago and it worked. ... but if you were to circle around the bike, one might say.... hey whats wrong with this light.... as you wil be able to pick out the leds behind the badge.. i "fixed" mine years ago, i would NOT do it again.. the amount of time spent on it wasnt worth the outcome. yes it was cheaper than $150, but it also didnt look OEM any longer either.
Godspeed
Posted 2014-09-02 10:05 PM (#165724 - in reply to #152512)
Subject: RE: Lighted Badge burnout repair.
Denver, Iowa
my badge
(bike logo 121.jpg)
Attachments bike logo 121.jpg (31KB - 3 downloads)
Bigmax
Posted 2014-09-21 3:08 PM (#165998 - in reply to #152512)
Awesome job and info. Thanks. I have already replaced one side and will more than likely resort to your method next time this happens.
Harbiejoe
Posted 2014-09-29 9:53 PM (#167134 - in reply to #152512)
Springfield Mo.
Lost the chrome bezel off of mine and had to buy a whole new light to fix it. They ain't cheap. Guess I now have an extra lighted badge now if one ever goes out.
icemann
Posted 2014-10-06 10:14 PM (#167222 - in reply to #152512)
, OH
I just did this. Wish I would have found this first but I did the same thing. Only difference is I used WHITE LED's for a little brighter. I have them side by side. Factory and led with photos for the difference. It's so close that being on opposite sides of the bike you would never know.
Because the led strips, as pictured above, illuminate facing outward, and not on the leading edge. The led strip when placed inside the housing lays on the "EDGE" so the led's shine left and right not OUTWARD. if the LEDS were shining on the edge and not shining the face, and the led's faced outward they would be super bright. (aka if it were a book, shine on the spline outward not the flat cover side).
I will post pics.
Big six
Posted 2014-10-08 7:07 PM (#167250 - in reply to #152512)
Thanks man. left side now.
