| Is King-bagger still around with his center stands? |
| maybe this will help. By the way most will tell you it scraps
http://buywitchdoctors.com/p/646/Victory-Other-Cool-Stuff-Center-St... |
Posts: 1066 Peru, IN | It's my understanding that Witchdoctors center stand IS King-Baggers. If so, it doesn't scrape. The OEM (Victory) version DOES scrape. |
Posts: 1632 Jasper, MO | Monkeyman - 2014-02-01 7:11 PM
I believe that is correct.
Ronnie |
Posts: 77 Bainville, & Mesa, AZ, MT | Kingbagger is still around on the VMC site, if you can't get on let me know and I can get you his contact info. |
Posts: 135 Yellowknife, NT Canada | took my center stand off my Vision last week. Lots of scraping while cornering. I had it on as an emergency support to work on the bike on trips. (One weld let go, springs fell off, it has been a lousy investment since I purchased it. Victory could have done a much better job with this. Don't buy this unit. Not worth your time to look at it.
Here is the one from Witchdoctor. I have not used this one, yet..
http://buywitchdoctors.com/index.html?product_id=646&category_id=&n... |
Posts: 3773 Pittsburgh, PA | does the Kingbagger one raise the rear wheel off the ground? |
Posts: 1632 Jasper, MO | Arkainzeye - 2014-05-28 8:16 AM
Don't think so. Too much rear suspension travel. However, I've been told that it takes enough weight off the wheel that you can turn it.
Somebody needs to copy the old Kawasaki Voyager XII two stage centerstand and adapt it to our bikes. It would lift the bike well off the ground and was very easy to operate.
Ronnie |
