Posts: 40 Griswold, CT | how much free play does the hyd clutch lever need
clem |
| no way to adjust
Posts: 40 Griswold, CT | that what i was thinking
no way better to get the right answer then right here
clem |
clem |
Posts: 573 Central Illinois | The spec for the clutch means that you go to the other end, where the clutch actually interfaces with the main part of the bike on the left side and try to find any slack in the entire process. If you have any free movement there, clutch is set right. On the day I took delivery on my Vision I thought the late engagement of the clutch was wrong. I turned around within 5 miles and went right back to the shop. They contacted Victory for clarification and that is what they were told. Here I am 6800 miles later with no problems. |
Posts: 40 Griswold, CT | i stopped at the dealers today as you said there is a little play
they checked it for me
said this is all the play you need
never had a hyd clutch before so i had to find the out if this is ok
THANKS
CLEM |
