| I have some major cracking on some plastic body parts in a few places. Is this something others have had and will it be covered under warranty? I have a 2011 with 31.000 miles. This does not include the front fender I already replaced. |
Posts: 1365 Central Maryland | Nope. And Nope. |
Posts: 499 Chattanooga, TN | Hold on willtill. Cracking is not just cosmetic. Could the frame be the issue causing the cracking? I'd check with your friendly Victory dealer! |
| not knowing where the cracks are. NO warranty
start looking on ebay under victory vision |
Posts: 1066 Peru, IN | ANY cracks are "cosmetic and wear and tear". Period. this is straight through Victory. Mother Vic knows best and will always do what's right for us, here owners, riders and children. |
Posts: 1308 Sand Rock, AL United States | no cracks nowhere |
Posts: 3773 Pittsburgh, PA | NO warranty.. "read the fine print of your agreement" and no never had this happen on (2) Different visions..
another short story.. on my 08 vision i had the Rear floating rotor fail on me... NOT wear out.. but fail.. even the dealer thought it should be covered under the extended warranty.. the round circles (sorry just woke up and cant think) failed.. the rotor went side to side and just about fell apart.. The extended warranty company through Victory didnt even want to hear about it... or hear about in the way that it failed... they said... simply... refer to the warranty papers you signed... so we did.. and there it was.... NOT COVERED.. doesn't matter what the reason was.. not covered is not covered...
=( i was pissed.... |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | I had one of the plastic mounting tabs break off for the aluminum fairing. Doesn't seem to bother anything. There are eleventy million screws holding that thing on, so I guess one isn't going to make a difference. Can't see it from the outside of the bike so left it alone. No other broken plastic. |
| well I'll check with my dealer, I had no problems getting the front fender replaced last month. We'll see.... |
Posts: 178 LaGrange, GA | Arkainzeye - 2013-09-29 10:30 AM
=( i was pissed....
I had that problem twice with extended warranties on vehicles, and that taught me to not bother buying another one. I see a lot of people praise them and get great support, those people are just a heck of a lot luckier than me. |
Posts: 3773 Pittsburgh, PA | Now ill be honest, on my 08 vision I had the green neutral light go out.. there is No bulb to replace. The unit was $900 !! So my extended warranty covered that. |
Posts: 825 , WI | I was expecting cracked body parts when I did the ride to Alaska. I had Ty-Wraps, duct tape and epoxy with but I didn't need any of it.
No cracks or repairs needed. |
Posts: 499 Chattanooga, TN | Exactly, Rollin. Which is why I think it is very odd he has cracked body parts unless there is something else causing the problem. If so, then I would think it should be covered if it is due to manufacturing. |
Posts: 161 Oregon. | Rollin,
Read about the IBA ride you did this last summer. Congrats. I have not been able to ride as much as I wanted to, oh well. Hope you had a great summer. |
Posts: 825 , WI | Brian G - 2013-09-30 9:02 PM Rollin, Read about the IBA ride you did this last summer. Congrats. I have not been able to ride as much as I wanted to, oh well. Hope you had a great summer. Thanks Brian! |
| Allaire5 - 2013-09-28 7:38 AM I have some major cracking on some plastic body parts in a few places. Is this something others have had and will it be covered under warranty? I have a 2011 with 31.000 miles. This does not include the front fender I already replaced. do you have photos |
Posts: 499 Chattanooga, TN | Any update on this? Covered or not, what's the cause of the cracking, where is it located, and got any photos? |
Posts: 3773 Pittsburgh, PA | CONTRACT DOES NOT COVER OR APPLY TO THE FOLLOWING CONDITIONS:
1. Any claim submitted without the authorization of the Administrator prior to starting the repair(s).
2. Any non-covered components or services, environmental surcharges, waste disposal fees, shop supplies, and similar charges including but not limited to, the performance of normalmaintenance services as set forth in the owner?s guide for the vehicle, scheduled replacement of parts and wear items, and parts and services such as: spark plugs, filter, fuses, battery, battery cables, belts, body parts and mounts, clutch friction disc, glass, lenses, non-permanent attaching parts, non-specialized bolts, clamps, windscreens, thermostat, head lamps and bulbs, timing belts, tune-ups, grommets, rubber or rubber-like hoses and lines, rubber tracks, paint, cosmetic trimparts, additives, freight, storage charges, core charges, brake linings, brake rotors, brake drums, complete exhaust system, upholstery. Fluids are not covered except in conjunction with repair of a covered mechanical breakdown. Fluid refill is limited to necessary amounts for one (1) refill on the covered component being repaired. |
Posts: 494 Akron Ohio area | My wiring harness "let the smoke out" while riding one day and it melted the front brake line and fried the heating elements in the seat.
The extended warranty paid for the wiring harness and the labor to replace it minus the $50 deductible.
I had to pay for the front brake lines and seat replacement.
Nothing rubber or plastic is covered.
No normal wear items are covered.
The brake line is, in their opinion, rubber or plastic.
The seat is considered a normal wear item.
