Posts: 249 Phenix City AL. | when my radio turns on instead of my regular screen I get $$$$$$$ it does it in all positions, I pod, Radio. XM. it seams to work but I dont get any music or channel info just $$$$$$$, is this victorys way of telling me I need to spend $$$$ or I am going to lose my radio? |
Posts: 46 Taylorsville, KY | Never seen that; but have you tried going into the radio set up menu to see if the display changes? |
Posts: 249 Phenix City AL. | Every screen has the same thing sometimes a random letter. |
Posts: 215 W'ford Tx | gotta give them credit for trying to have a sense of humor about your misfortune. Maybe contact the dealer, the radios can be flashed just like our ECMs so maybe a reflash to and updated software version might work. |
Posts: 46 Taylorsville, KY | With bike off, turn ignition to acc and turn off the radio. Turn ignition off, then back to acc. Press and hold 1 and mode and turn radio on.....this should get you into the set up menu. To exit menu turn the ignition back off....this may reset your display to normal....might want to scroll through the menu while you're in there to check for an error code. |
Posts: 66 Delray Beach, FL United States | also try disconneting the battery for 10 minutes. |
Posts: 1340 Gainesville Fl Home of the Gators | If reset does not work. The company that does the radio has a reasonable rebuild program for them
EDIT:......or you could get a Anti Freeze Green XC
Edited by kevinx 2013-09-23 10:51 AM
Posts: 249 Phenix City AL. | or a blue XC , I did the reset, that did not work, now I am going to try the power disconnect . |
Posts: 1324 So Cal | Needs a radio. Mine did that 2 years ago. 2008. warranty covered it. Johns radio makes them. At that time exchange was $175 + handling. Looked into it just in case warr. didn't cover it. |
Posts: 208 Edmonton Alberta, Canada | Did a Google for johns radio and found nothing. A web link would be nice please. |
Posts: 46 Taylorsville, KY | The radio is made by Radio Sound in Louisville,KY. www.radiosound.com |
Posts: 1632 Jasper, MO | Here is the customer service and repair rates http://www.radiosound.com/customer_service.php
Ronnie |
