Posts: 28 Hendersonville, NC | anyone know of any aftermarket heated grips or a clam shell like the kuryakyn iso grip to fit the 13 vision air cushion pads
thanks for helping |
| air cushion grip will rob you of some heat. If you pull the end cap off the bars I beleve you will see a aluminum rod not sure you can get by that |
| Avon
Posts: 135 Chesterfield, VA | As I stated in your other thread - Grip Puppies. Cheap and effective with no loss of heat through the grips. |
