| I just downloaded the most recent version of their software and also their most recent firmware. I noticed something I hadn't noticed before. They have an indicator on the software screen now that lights up when autotune is running which I don't remember seeing in previous versions. In any case, I noticed that autotune doesn't start working till the engine hits 2000 RPM. Below that the light goes out. Does anyone know if that is normal or due to a setting.
Update: Never mind I figured it out. I have the AFR table set to 0 below 5% throttle opening so the autotune doesn't start doing anything till it hits that throttle opening. It wasn't related to RPM. I changed one of the AFR tables to have a value in the 2% throttle column and that changed when autotune started working accordingly. All's good :-)
Thanks,
Marc
Edited by marcparnes 2013-08-18 1:29 PM
