handlebar risers
gary1
Posted 2013-07-06 8:30 AM (#141296)
Subject: handlebar risers
has any one seen any handle bar risers out their for the vision could use about a2inch up . any aftermarket co out their 2012 vv6k
atvtinker
Posted 2013-07-06 11:59 AM (#141301 - in reply to #141296)
Subject: Re: handlebar risers
Grand Cane, LA
I think you will be hard pressed to find anything over an inch. There is just not enough room between the top of the handlebars and the radio console. You'll more than likely be have to look for aftermarket bars.
Monkeyman
Posted 2013-07-06 6:15 PM (#141311 - in reply to #141296)
Peru, IN
I'd be surprised if you could successfully fit a 1" riser under there. The bars end in a flat piece of metal which bolts to the triple tree. Both Witchdoctor and HMD make bars with more rise and pullback.
Posted 2013-07-06 6:32 PM (#141314 - in reply to #141296)
maybe you could add a one inch spacer between bars and triple tree that would raise the bars
atvtinker
Posted 2013-07-06 9:15 PM (#141317 - in reply to #141296)
Grand Cane, LA
I have a 1 inch spacer in mine and the trim just above the bars almost touches the bars now. If you trim that piece you might get another 1/2" at most because you would hit the bottom of the switches or radio.
