| I guys I how you all can help me out. Today when I started my bike I had no sound what so ever I rode the bike friday and every thing was fine. I took a look at it all I can really see is that everything seems to be working Ipod it shows the song on the read out I can skip it the volume gos up and down just no sound I know that allmost every one here is like a tec guy so what do you guys think.
Posts: 1632 Jasper, MO | I think you accidentally hit the mute button.
Ronnie |
| crash-bar - 2013-06-11 10:43 AM
Do you have a GPS hooked up to the bike? |
| nope I looked at the mute turned it on and off still nothing it shows mute when I hit it and will turn off when I hit it again like I said the whole thing seems to be working just no sound..@ Turk no GPS just an Ipod hook up. |
Posts: 366 Albuquerque, NM | Having ridden with you cb and heard how loud you rock that sound system....I'd say you blew all 4 speakers simultaneousely! Just kidding. I suppose it does the same on FM. |
Posts: 8144 New Bohemia, VA | if you had the console off recently it may be the harness plug. also, like nailer mentioned, does the other modes work, FM, AM, WX? |
| Or try a battery disconnect . Sometimes the computer needs a reset.
Posts: 691 Manchester, CT | Not wanting to state the obvious..but...does your iPod work when headphones are attached? |
Posts: 576 , IA | Did u check internal or external bot tom
Posts: 576 , IA | Did u check internal or external bot tom for speakers
Posts: 1066 Peru, IN | Did you accidentally turn the speakers off? Somewhere in the menu, there's a setting to turn the speakers off. Make sure it's on. (Unless that's what sonicbluerider meant.) |
| GOSH if you only would have told us the year of the bike that would of been nice |
| I DO not have my radio that loud........................OK maybe its a little loud ha ha dose anyone know if there is a fuse just for the speakers?? like I said everything seems to work right just no sound I checked the interal and ex mod there are on no panels have been moved the year is 2009. I have not disconnected the battery yet going to do that tomarrow. by the way NOW I know that the trunk and gear shift dose make noise and so do the cars around you WOW!!!!! |
Posts: 133 , AR United States | Victory replaced my radio twice in 2010 under warranty. The second time was for no sound at all. Has your software been updated? Later I added the ipod cable, I have to use a rubber band to keep it plugged in. |
Posts: 691 Manchester, CT | No fuses required between speakers and audio amp |
