Posts: 294 rhode island | Anyone having an issue with them going on an off by themselves.
I think the wiring is being flexed to many times by the fork travle.
Havent found the break yet.
Edited by sandman 2008-07-17 7:23 AM
| Mine go off when I run the brights on the headlight but no other problems. |
| No problems with mine that I am aware of.
The Poconos | No problems with mine. |
Posts: 296 Central Florida | az rob - 2008-07-17 8:15 AM
They are supposed to do this! HID goes off as well when hi-beams are on! |
Posts: 294 rhode island | Devil boy
I've got one thats out then comes on then out again then blinks, not sure if this is what they had in mind. p.s H.I.D is supposed to stay on regardless of high beam.
Edited by sandman 2008-07-18 1:07 PM
| Marc, Mine stay on with low and/or high beams. Tim |
Posts: 296 Central Florida | sandman - 2008-07-18 1:05 PM
Devil boy
I am sure that is NOT supposed to be happening! I routed my wiring UNDER and behind fender and behind fork legs. If one is blinking on and off, I would guess bad connection. First thing I would try is pull relay out of fuse box and reinsert. Then check bullet connections on both lamps.
this SHOULD be plug and play... BTW my HID stays on with High beams, but PIAAS go off with highs.. who can figure??? |
