Engine transplants
XRsteve
Posted 2013-05-17 6:34 PM (#139133)
Subject: Engine transplants
Georgia, west of Atlanta
Will all 2008-2013 Victory Freedom 106 engines fit in a Vision frame ?? I'm not sure if mounting points on the heads are the same for CC bikes, Hammer style bikes and Visions.
Chico7z
Posted 2013-05-17 9:27 PM (#139137 - in reply to #139133)
Subject: Re: Engine transplants
Barrington, NH
Should all be the same
Posted 2013-05-17 10:13 PM (#139139 - in reply to #139133)
While the engines may fit, there may be other issues related to the electronics that may need swapping out also.
XRsteve
Posted 2013-05-17 11:45 PM (#139141 - in reply to #139133)
I'm thinking of getting a Ebay engine or engine from Insurance total loss division to use the top end for building purposes. I want to have the cylinders big bored with the iron sleeves to 116 cu in and the heads ported and big valved. This way I'll have very little down time. Plus I can do this at my leisure and really find out how these things tick. Knowing how much air a stock head flows @ 10" pressure before and after porting, stuff like that. I like to know all about the internals of engines. I know almost everything there is to know about hot roddings Harleys. But now I'm a Victory man..........So I want to become more educated in the ways and means........
Edited by XRsteve 2013-05-17 11:46 PM
Posted 2013-05-18 6:53 PM (#139159 - in reply to #139133)
would think and 106 frame would except any 106 motor.
No you could not put a 106 in a 100 frame.
Vic hasn't changed the motors except for the gears. Best thing would be to call Lloydz and get his advice first
By the way we all ready have steel lined cylinders. Ask Lloydz about the tranie gears too
Posted 2013-05-18 11:24 PM (#139166 - in reply to #139159)
johnnyvision - 2013-05-18 6:53 PM
I believe the stock Victory motors are Nikasil coated aluminum.
XRsteve
Posted 2013-05-19 10:45 AM (#139174 - in reply to #139166)
rdbudd - 2013-05-18 11:24 PM
Correct all stock Freedom 106 engine cylinders are Nikasil lined. The 116" big bore kits use cast iron liners for structural rigidity. I'm not sure about the older 110" and 114" big bore kits. If you are really interested call Lloyd Greer, he'll tell you.
Vicbuilder
Posted 2013-05-21 5:52 AM (#139289 - in reply to #139133)
Subject: RE: Engine transplants
The Vic Shop - Central Iowa
One step ahead of you...
(IMG_20130520_140112_443.jpg)
Attachments IMG_20130520_140112_443.jpg (157KB - 1 downloads)
XRsteve
Posted 2013-05-21 8:32 AM (#139295 - in reply to #139133)
What year, model and all that jazz ?? What are you gonna do with it ?? 116 ?? Supercharged ?? Giant valve ported heads ?? Bigger throttle bodies ?? Let us know whats up ................
marcparnes
Posted 2013-05-21 8:40 AM (#139297 - in reply to #139289)
Vicbuilder - 2013-05-21 3:52 AM
"Made in China"?
Marc
Vicbuilder
Posted 2013-05-21 8:54 AM (#139299 - in reply to #139133)
The crate is from something else - no the engine did not come from China!
I plan on going 110" Nikasil with this one. It is going in my '08 Vision.
Vicbuilder
Posted 2013-05-21 8:56 AM (#139300 - in reply to #139133)
I'm trying to beat the last 110" Vision I built this winter, here is it's chart. Hoping for closer to 130's, but we'll see.
EDIT: DAMN CHART IS TOO BIG TO ATTACH!
Edited by Vicbuilder 2013-05-21 9:03 AM
(110 0timing onPC [320x200] [50%].bmp)
Attachments 110 0timing onPC [320x200] [50%].bmp (52KB - 13 downloads)
XRsteve
Posted 2013-05-21 10:21 AM (#139303 - in reply to #139133)
Rylan I'm sure you'll know, will any freedom 106 fit in a Vision frame ??
Vicbuilder
Posted 2013-05-21 3:57 PM (#139318 - in reply to #139303)
XRsteve - 2013-05-21 10:21 AM
Yes.
Posted 2013-05-21 5:13 PM (#139325 - in reply to #139133)
Will the 111 Thunder Stroke fit the Vision?
ScoreBo
Posted 2013-05-21 6:58 PM (#139337 - in reply to #139133)
Northeast Ohio
Chris, you are bound and determined to get that Indian, aren't you?
Posted 2013-05-21 8:13 PM (#139347 - in reply to #139325)
varyder - 2013-05-21 5:13 PM Will the 111 Thunder Stroke fit the Vision?
NO NO NO
