Posts: 28 So. Indiana | With the addition of ABS, did it change the wheel setup? Could you in theory use newer wheels on older Visions? |
| Definitely makes no difference at least on a 2011. I had 8-Ball wheels on my 2011 Tour and they bolted right on. The Tour had ABS and the 8-Ball didn't. The ABS sensor ring attaches on top of the brake disc carrier with the same bolts that hold the carrier on.
Marc
Edited by marcparnes 2013-05-17 2:25 PM
Posts: 309 Vineland, NJ United States | I put 2012 rims on my 2008 Vision, no problems. Checkout thread and pic http://www.vision-riders.com/bb/forums/thread-view.asp?tid=13690&posts=9&mid=138488&highlight=2012+rims+on+2008&highlightmode=1&action=search#M138488 |
Posts: 170 Barrington, NH | The reluctor for the ABS is a bolted on part so the wheels are interchangable! |
| most ABS triggers are a aluminum button on the rotor. Maybe just on one rotor.
Am sure the wheels will work for you |
Posts: 28 So. Indiana | Thanks! Good to know. Ive never personally cared for swept wheels. Those 8 ball rims look good on there! |
| marcparnes - 2013-05-17 2:22 PM
Marc
I agree with you. |
| Lala55 - 2013-05-24 2:03 AM
Marc
I agree with you.
As long as your feet are cloaked in skates, the FlyRad unicycle can then be used to drag you along at up to 40km/hr. You can even sit on it, or stand?it's a plethora of silly transportation options......
