Posts: 39 Reedley, CA | 185/55-16 HANKOOK VENTUS V2 CONCEPT 55R R16 TIRES
anyone run these on darkside |
Posts: 142 elgin mn | I RAn a 195 55r 16 ventus v 4 was a good tire replaced at 16000
| I also tried a Hankook. I didn't like it, the Ventus has a very soft sidewall, on hard turning with acceleration you can get a lot of flex. My ventus only lasted to about 13k and was shot. I am on the aggressive side in my riding style. After the Ventus I went to a Michelin alpine RF. I will stick with the Alpin, 19k on the tire with lots of mikes left. Smoother ride and better cornering.
Good luck |
Posts: 54 Bancroft Ontario, Canada | is your Michelin 185/55 16? |
| Got ya, running a hitch I see. The alpin doesn't come in 185. However the Dunlop winter sport does, I know a lot of guy here us them, and I've seen nothing but stellar reviews.
| Cletisv - 2013-04-25 7:42 PM 185/55-16 HANKOOK VENTUS V2 CONCEPT 55R R16 TIRES anyone run these on darkside Do you think you posted this enough times |
| jeffmack - 2013-04-25 11:56 PM
Ummmmm, that is an unbelievable understatement.... It is ok to be humble you ;'0$%#^&&&%$##@@%%^ freakin maniac. HOLY CRAP!
Here's an idea, why don't you post a pic or two of the bottom of your VIC???????
I say that only with the utmost respect BROTHER.
Edited by Ditch 2013-04-26 9:56 PM
| johnnyvision - 2013-04-26 8:00 PM
Cletisv - 2013-04-25 7:42 PM 185/55-16 HANKOOK VENTUS V2 CONCEPT 55R R16 TIRES anyone run these on darkside ? Do you think you posted this enough times
Purely out of curiosity do you just respond to everything just for the hell of it? Or have you completely forgotten how it was when you got your Vision? Maybe you were born a Vision Expert......Just so you know, most of the rest of us were not born into brilliance.
Edited by Ditch 2013-04-26 10:02 PM
Posts: 7 pratt, KS United States | just bought 09 midnight cherry vision where can you find the dunlop winter sport,my guy at the local tire shop can't seem to find them and the dealer will not reply on putting it on for me ..I know wa wa cry baby right. |
Posts: 1066 Peru, IN | old-bones - 2013-05-02 6:26 PM
...where can you find the dunlop winter sport...
http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=S... |
Posts: 54 Bancroft Ontario, Canada | Eh...i have been frustrated as hell trying to go to darkside.....i have a hitch so limited to 185 or 175.....cannot get dunlop run flats.....cannot get Michelin....cannot get bridgestone g109s....could not find Hankooks but lucked out Fri and found 2 through Canadian Tire.....now i have them i see concerns over the skimppy sidewalls.....they sure are thin....tire says god for 1074 lb at 51psi
Question ......those that have run the Hankook's what pressures did you try??
Thanks
Bear |
Posts: 185 Rhode Island | Still running the Winter Sport but will consider this when I need a tire; don't know anyone that has run one yet.
http://www.goodyear.com/en-US/tires/assurance-fuel-max?ub=Y&updatec...
Jim |
Posts: 135 Chesterfield, VA | I am currently running the Goodyear Fuel Max 175/60-16 (see sig line below) on the rear of my 2011. I've been running this tire for about 8,000 miles with no problems. I originally got this size because I had a hitch installed. I've since removed the hitch, but have lowered the rear 2 inches. I run between 36-38 PSI in the tire. It handles well in the rain and I have ridden the whole BRP and Dragon with this tire with no problem. |
