Windshield gormmets
Jimbo62
Posted 2013-02-28 2:01 PM (#131532)
Subject: Windshield gormmets
I there a p/n for the grommets (6 ea.) that are installed on my '11 Vision windshield?  The ones currently installed are/were probably over torqued on initial install at dealer, and are extruding out from under the screws heads.
okie vision
Posted 2013-02-28 2:44 PM (#131534 - in reply to #131532)
Subject: Re: Windshield gormmets
Broken Arrow, OK
WSHR-FL,11X18X1.59MM Part #5813188 $0.44 ea
Jimbo62
Posted 2013-02-28 9:11 PM (#131549 - in reply to #131534)
Thx.
Turk
Posted 2013-03-01 8:01 AM (#131566 - in reply to #131532)
Subject: RE: Windshield gormmets
Jimbo62 - 2013-02-28 2:01 PM
I there a p/n for the grommets (6 ea.) that are installed on my '11 Vision windshield?? The ones currently installed are/were probably over torqued on initial install at dealer, and are extruding out from under the screws heads.
That's because they weren't installed correctly, as was the case when I first got my bike. They belong on the underneath side of the windshield between the shield and bracket, not on top of it under the mounting screws. Do not over torque the windshield screws.
I also discovered that the flange bushings that are part of the windshield bracket to motor connection were improperly installed. Once I turned them around, the slop in the windshield all but disappeared.
