Posts: 65 Newburgh,IN | Hey Guys:
I can't find a way to attach pic's, Need some help.
Thanks
Dave |
Posts: 495 Carrollton, TX | Just before submitting your post click on the box for attach files after posting and it will take you to a screen at the very end prompting you for the atachment. The key is the attachment needs to be no more than 90 KB in size. |
Fountain Inn, SC United States | What Spock said! It also helps to have the photo no wider than 600pixels otherwise it skews the page.
Posts: 235 Evergreen, CO | I haven't tried posting pics either...thought I would give it a try here.....Thanks for the destructions!
Posts: 235 Evergreen, CO | Hey, once I tried to post, it limits file size to 60K, not 90K. I first shrunk my pics down to ~85k and it would not accept the attachment. |
Posts: 174 Edmonton, AB | I believe the size limit is under 60k for postings in a thread and under 90K for postings in the Gallery. |
Posts: 65 Newburgh,IN | Can't ssem to find the place to attach files. |
Posts: 600 Linwood, MI | Uncle - 2008-07-06 8:15 AM
First off, make sure you're using the "Reply" button in the bottom right corner of the page rather than the Quick Reply area directly under the last post. If you are in the Reply screen you should see a check box and the words "Attach a file after posting" right above the "Submit" and "Preview" buttons. Check that box and you're off and running. |
Posts: 65 Newburgh,IN | Trying it again. |
Posts: 57 Twin Cities, MN | My turn to try - Worked for me... Ted - I love the personalized plate - NOMOHD PERFECT!
Edited by Grebs_59 2008-07-10 6:40 PM
