Posts: 411 Dallas, Texas | I am not quite sure how, but it seems as though the center shaft lever sheered off on my heel to toe shiter on my 08 Vision. My real question is, does the heel to toe shifter use the same hardware as the original shifter? |
Posts: 48 huntington In. | Yes just replaces it |
Posts: 411 Dallas, Texas | willieh - 2012-12-24 2:57 AM
Thanks Bill. I'll just order some new OEM hardware. I wonder if this is at all common. First time it has happened since I purchased it new in July '09. Dealer had installed the heal to toe shifter and installed it as part of the deal. Does it usually need mush lube/maintenace on that shaft/shift lever? Just curious. |
| I've had the same heel/toe shifter on my 08 since I purchased new and it's always worked great. Never thought about needing to perform any maintenance on it. I'll definitely look at this during next service now. |
