Posts: 25 Tyler Texas | Out for a ride today made a left turn used signal went to cancel signal light noticed it wasnt blinking just lit up on left side turned off the bike started it backup left signal still stuck drove it home pulled the relay in fuse block reinstalled same thing so i pulled the relay for secondary light installed it in the signal relay spot still the same problem left signal stays on no blinking,will not shutoff right signal blinker does not work hazards do not work either maybe its the signal switch any thoughts to the problem.tnx |
| stifsmit - 2012-12-03 6:49 PM
Sounds like a bad ACM (auto cancel module).
Posts: 599 New Mexico | Was going to say sounds like might be a ground, but after looking at the wiring diagram, I agree with Turk. Is the only thing I see that is common to all your symptoms.
The ACM has a self-test mode listed in the manual, pg 19.13. I tried to cut and paste but could not.
