| i find it difficult sometimes to locate kickstand to put it down. need a bolt on piece. where can i get one? |
Posts: 499 Chattanooga, TN | Are you talking about the black rubber pad that goes on the kickstand? I replaced mine with a new one from the dealer. Had to cut off the old one with a hacksaw and rivet the new one on. |
| no, not the rubber. looking for an extenion type piece to clamp or bolt on to make the stand easier to put my heel on. |
Posts: 1066 Peru, IN | Witchdoctor has extensions in black, chrome and silver. $20-$34. You lose the rubber pad, though.
http://buywitchdoctors.com/p/1752/victory-motorcycle-parts-other-st... |
Posts: 130 Houston, Tx | $20 here: http://www.noemtz.com/kickstandextensions.htm |
Posts: 1365 Central Maryland | Monkeyman - 2012-11-15 3:28 AM
I'd recommend trying to somehow keep the rubber pad. That pad does work to help return the sidestand into the stowed position; in the event that you inadverently forget to put it up before taking off (been there, done that). That is the primary purpose of the rubber pad.
Not sure if you could somehow remount it when using the extension though.
Edited by willtill 2012-11-15 2:21 PM
Posts: 785 Mt. Vernon, WASH. | You guys are working the wrong end of the side stand, Banjodan is speaking about the microscopic nub that hugs the exhaust pipe and is supposed to be used to extend the side stand from it's 'stowed' or 'up' position to the 'extended' or 'down' position and what a P.I.T.A. it is to locate, grasp with a waffle like boot heel, and extend so the bike doesn't land on the tip over or frying your calf on the pipe, he's NOT talking about the traction pad on the bottom that touches the ground when the stand is extended. It ain't that hard, stop over thinking simple stuff- |
Posts: 1365 Central Maryland | SYNSTER, I think everyone here UNDERSTANDS the issue. I think you do not UNDERSTAND the responses that have been posted. Re-read the thread. |
| thanks willtill. didnt know the pad was a saftey thing. i have forgot [several times] to raise the stand, with no mishaps. i better keep the rubber pad. i'll give it some more thought. maybe i can clamp a small tab or something close to the [micronub] lol. to make it easier to locate.
Edited by Banjodan 2012-11-15 5:32 PM
| hardware stores sell narrow strips of aluminum you can bend it the way you want. Drill out the two rivets and bolt your custom made peace to the top of the rubber boot. You can get button head allen at the same hardware store.
| Just drilled a hole and bolted a 3/4 spacer on the end, works great! |
Posts: 8144 New Bohemia, VA | While you can mod it, you can also practice the placement of your heel to drop it like second nature. |
Posts: 2118 Pitt Meadows, BC Canada | varyder - 2012-11-15 5:06 PM While you can mod it, you can also practice the placement of your heel to drop it like second nature. +1 |
| I have the Extender....it returns the kickstand up just fine......not that that has happened or anything.. |
Posts: 8144 New Bohemia, VA | donetracey - 2012-11-15 8:41 PM varyder - 2012-11-15 5:06 PM While you can mod it, you can also practice the placement of your heel to drop it like second nature. +1 No enhancements needed to find the tang, right, Don? |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | Don't the newer Visions have an extension on the kickstand stock? Anyone know if a new kickstand will fit on an 08~09 bike? |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | Here is the stock stand for a 2012. This way you get an extention that looks clean and you get to keep the rubber thingy. Now, does anyone know if a 2012 kickstand will fit Banjodan's 2009?
http://www.thevog.net/marketplace/642/victory-vision-stock-kickstan...
Edited by victoryvisiontour 2012-11-15 8:58 PM
Posts: 1066 Peru, IN | I'm pretty sure my '12 Vision doesn't have that extra part on it. I'll have to double check when I get home. |
| some good ideas guys..thanks |
Posts: 394 Tucson, AZ | I put a chrome one on my Vision and it helps quite a bit. Hardest part is hack sawing the stock rivets off. |
| I like that 2012 stand, might have to look into getting one. |
Posts: 1066 Peru, IN | If that's a kickstand for a '12 Vision, it's some sort of aftermarket. It's NOT stock. |
Posts: 8144 New Bohemia, VA | are you all still discussing kickstand dysfunction?
Edited by varyder 2012-11-17 1:21 PM
Posts: 1066 Peru, IN | Only kickstands with an extra bend in them. |
Posts: 1365 Central Maryland | varyder - 2012-11-17 2:21 PM
Ya |
Posts: 2118 Pitt Meadows, BC Canada | Mine has worked fine for 4 years .... took me a few stabs to figure out where is was hidden - once I found it - never had a problem.
| here a some to chose from. You might have to drill out your rivets and put in new bolts
https://www.denniskirk.com/search/kickstand+extension.q |
| That picture for the 12 sure looks like the extended one I bought for my 09. Where the bolt goes thru the eyes up at the top ,mine cracked and keep leaning more and more,so I looked at it and saw it was broken,found the original. Thought I'd get another one but still using the original one,but would be much easier if it had more of a tang extended out for me. May this info will help ya! |
