| Hello Can someone tell me how much are victory vision tires installed and where can i go here in Louisiana? |
Posts: 324 New Orleans, La, | Louisiana is pretty big, where are you in Louisiana? |
Posts: 1632 Jasper, MO | Welcome. It will all depend on what tires you choose to use and where you have them installed. The tire prices will vary a lot depending on where you source them. Our Visions use the same tires as the GL1800 Goldwing, so checking the internet for Goldwing tires will usually turn up some good deals. I usually just have my dealer source and install the tires and they price match the online price deals and charge me about an hour shop rate to change both of them ($75). Check some of the online deals and see if your dealer will match the price if you let them get the shop work. You should be able to get both tires for about $300 or so plus installation. http://wingstuff.com/shop?keyword=gl1800%20tires&sitesync=done
http://www.jakewilson.com/search?term=honda+gl1800+tires+bridgeston...
http://motorcycle.motorcycle-superstore.com/motorcycle/Gl1800%20Tir...
Put your location in your signature line so we know where you are and can direct you to area dealers.
Ronnie |
Posts: 499 Chattanooga, TN | Just a suggestion, if you have the stock Dunlop E3s and your front tire has a 3/4" strip of tread down the center, or the road howl is bothersome to you, I've found the Bridgestone G704/G709 combo an excellent alternative to the stock tires. Just thought I'd give my .02 |
