Posts: 78 Gilroy, Ca | Been looking around at exhaust systems (Big Honkers, Thunder Cones, Atom Bombs, Witchdoctor, RPW). Which pipes give the performance while also having good sound |
Posts: 880 Orlando, FL | The ones you like the best. Check out You Tube. Lots of sound/video recordings there of various pipes. |
Posts: 78 Gilroy, Ca | Ok so how about performance |
| Do some homework and you will find lots of info on this site and others...VMC also has lots of info.....As said above do what is right for you...It your dollar!!
Edited by opas ride 2012-10-07 5:44 PM
| your not going to pick up that mush power. There all about the same. The only way your going to get power is with cams.
Pipes might give you 5 to 7 horse thats if you add top air filter. |
Posts: 259 Land O Lakes, FL | Drill out the stickers. Sounds great and its cheap! Hole saw and 24" extension cuts the baffle plate out nicely. |
Posts: 78 Gilroy, Ca | I'm looking to do both filters, exhaust and a power commander for now might do cams later |
Posts: 185 Rhode Island | Check out some combinations here.
http://www.lloydz.com/dyno.asp
Jim |
Posts: 78 Gilroy, Ca | What's the VIP stand for? |
Posts: 185 Rhode Island | It is the top air intake, Lloyd has a newer model out now. I would like to see some postings with the new adjustable air intake and a set of D&D pipes. I know Lloyd is now a dealer for D&D so I have to believe they are on the short list of top performers.
Jim |
Posts: 78 Gilroy, Ca | Man these engines make gobbs of power with just the VIP and Honkers |
Posts: 1632 Jasper, MO | johnnyvision - 2012-10-07 6:06 PM
And the extra 5 to 7 horsepower comes from the top filter, even with stock pipes. Stock pipes aren't restrictive--just quiet. Cams, top intake filter, and fuel controller are good for a 30% power increase--stock exhaust or aftermarket.
If on a budget, do the top intake filter and a VFCIII and poke a hole in the stock mufflers or put Thrush mufflers on for sound. Add VM1 cams when you get serious. Add Lloydz reprogrammed ECU to top it off.
Ronnie |
Posts: 1632 Jasper, MO | PhantomX - 2012-10-07 6:15 PM
A piece of steel pipe angle cut to a sharp point and a BFH is cheaper and easier and faster. Does the same thing--puts a big hole in the inner baffle plate. I used to do it to my Japanese sport bikes. My Vision is staying quiet, but if I wanted to listen to all that noise I would get out my piece of pipe and 3 pound hammer.
Edited by rdbudd 2012-10-08 11:44 AM
Posts: 1290 Ruskin, Fl | I have Big Honkers. Sounds good when you get on it, but not too loud for a 400 mile ride.
Much better than the S1L1 I had. |
Posts: 537 , FL United States | Cw. What kind of tips do you have with your Big Honker. I have the Kewl Metal flame tips...they are open... bike sounds good... |
Posts: 2300 Georgia, west of Atlanta | Sound: CFR's and Thunderheaders sound great and not too loud. Performance is really in fuel controller, cams and free flowing air cleaners. |
Posts: 1290 Ruskin, Fl | I have the Victory gatlin tips. |
Posts: 216 Danville, CA | Love my thunderstix. A tad loud when going for long Multi day rides. I'll live with it. Sounds tough. |
Posts: 2118 Pitt Meadows, BC Canada | In Vancouver, they are IMPOUNDING bikes with LOUD pipes - heavy fine to get your bike back. Harley boys are suffering big time.
Keep in mind it might happen in YOUR town someday. And keep in mind it might happen in some place you are driving thru.
Posts: 880 Orlando, FL | don that's true, but until it does happen in the U.S. of A. ........RIDE HARD, LIVE FREE, and MAKE 'EM LOUD!! |
Posts: 8144 New Bohemia, VA | I guess better not ride north right now, I'm shootin' flames from the hole in the pipe.... |
Posts: 8144 New Bohemia, VA | Durn iPad, like a Harley lobbing on me...
Edited by varyder 2012-10-11 9:18 PM
Posts: 8144 New Bohemia, VA | Potato, potato, potato,..,.
Edited by varyder 2012-10-11 9:19 PM
Posts: 8144 New Bohemia, VA | Ppppfffftttt.....
Edited by varyder 2012-10-11 9:20 PM
