Posts: 3204 Memphis | I've let my dealer do all the maintenance on the bike but I get it serviced every 3,000 miles (2 months) instead of 2,500 by the book. They did the 10,000 service when I took it in at 9,000 miles. Here's what they did: Belt tension/alignment (it wasn't chirping), oil/filter change, air filter clean/re-oil (Stage 1/Level 1), check brake fluid/rotors/pads (not even half worn), fault code check, compression check, clean spark plugs (they were grey, still original, runs perfect. I don't blip it or bog it.), check tires (will probably change the rear at 12,000), checked every switch, gauge and light on the bike. Total time: 1hr 15 minutes Total cost: $110.00 (My other check-ups were between $90-100) Peace of mind until the next visit....priceless. |
