| I want to remove the Swoosh's to paint and wonder if there is a step by step insturction article by someone out there? i can't seem to see all the bolts that need to be removed for tin removal...
TIA for response |
Posts: 935 Rockford, IL | I've had my Vision completely apart three times now and from everything I can see there really isn't any easy way to remove the swoosh panels without removing the lower fairings which requires removing the upper fairings which requires removing the console fairings and there are also a few other items like the tipovers and the lower belly fairing and such.
So as long as you have some time and patience and perhaps a helper......you are all set. |
| Guess i'll be doing this when the snoflakes fall...
Thank You |
Posts: 241 Monrovia, Ca | 2 hours max, including a couple of beverages. 6 & 4 mm hex wrench's and a 10 mm socket is I think all you need. I e mailed you the instructions in a file.
Edited by LA Victory Rider 2012-09-28 6:02 PM
| Anyway I can get a copy of those instruction too? Sounds like something that should be here online! |
Posts: 935 Rockford, IL | rebelce - 2012-10-23 2:07 PM Anyway I can get a copy of those instruction too? Sounds like something that should be here online! Can download the instructions via the link within this link http://www.vision-riders.com/bb/forums/thread-view.asp?tid=1924&...
| Thank you! I down loaded them all. |
