| i noticed on my 2012 vision the right side is about a half inch ormore higher than the left side still under warrenty how do u get into where the electric motor mounts up probally asimple fix |
Posts: 46 Taylorsville, KY | You can probably raise rhe windshield up and loosen connection bolts through the existing slots to aanda it. Mine was crooked enough to rub on the left side with the windshield all the way down and I was able to straighten it up this way. |
Posts: 880 Orlando, FL | gary, did you just buy the bike? Makes you wonder what else they overlooked when they set up your ride!
| yes idid about a 5weeks ago like the ride and handeling trying to get afew minor things taken care of thanks |
Posts: 3773 Pittsburgh, PA | sounds like a dealer prep issue |
Posts: 44 Middleburg, Fl. | Mine has been like that, (about 1/2 inch low on the left side as viewed from the cockpit) since I got it and it was bugging me - so - while I had the front panel off (I was tinkering with the front turn signals to make both bulbs on each side flash), I removed the trim on each side that the windshield "mounting arms" protrude thru (these are the arms of brackets or what-have-you that hold the windshield to the bike on each side and swivel to allow the windshield to go up and back down) - then loosened the nuts that hold the windshield "mounting arms" to their common shaft and held in windshield in the position I wanted while retightening the nuts. That fixed it! |
