Safety issue heads up
Trekwolf164
Posted 2012-09-13 11:32 AM (#123547)
Subject: Safety issue heads up
New York State
The front brake switch on my 2008 Vision failed at about 25000 miles.
The front brake switch on my 2011 Vision failed at about 15000 miles.
My dealer www.locomotionpowersports.com replaced it today under warrenty.
I was told this is a common failure.
So squeeze your front brake and check to see if your tail light lights up.
Posted 2012-09-13 11:41 AM (#123549 - in reply to #123547)
Subject: Re: Safety issue heads up
Last time I checked, but I'm going out now to see if it does...
...works fine...thanks for mentioning this!
Edited by varyder 2012-09-13 11:49 AM
Boots
Posted 2012-09-13 11:53 AM (#123550 - in reply to #123547)
New Mexico
My front brake switch went out as well. Lost brake lights & cruise control. No hassle warranty fix.
Edited by Boots 2012-09-13 11:54 AM
XRsteve
Posted 2012-09-13 3:11 PM (#123557 - in reply to #123547)
Georgia, west of Atlanta
Mine failed at 22,000 miles...........first indication: front brake wouldn't turn off cruise control..........
Gray rider
Posted 2012-09-13 5:56 PM (#123569 - in reply to #123557)
Tucson, AZ
27,800miles and mine is good.
mkultra
Posted 2012-09-14 5:54 AM (#123583 - in reply to #123547)
Tucson, AZ
Just replaced mine yesterday. It went out at 83K miles on a trip. Sure was strange having to use the foot brake pedal to release the cruise control.
mike
XRsteve
Posted 2012-09-14 7:33 AM (#123587 - in reply to #123583)
You got that right.......
MaddMAx2u
Posted 2012-09-14 6:59 PM (#123624 - in reply to #123547)
Orlando, FL
Checking to see if your brake lights work when using your front brake are part of ANY pre-ride check. Don't forget the lilttle things~!
DAL
Posted 2013-05-25 12:36 AM (#139506 - in reply to #123547)
Subject: RE: Safety issue heads up
Vancouver, B.C. & La Quinta, CA
That and the horn, turn signals and rear foot brake should be checked before you ride each day as a matter of routine.  That's what all the motor officers do...
Monkeyman
Posted 2013-05-25 6:52 AM (#139509 - in reply to #123547)
Peru, IN
I check the lights, turn signals, brakes, tires, etc before every ride.
Posted 2013-05-25 11:04 AM (#139519 - in reply to #123547)
Can this be reported to "someone" for a potential recalls. Thats fine you can check it before you ride, but what if it breaks while you ride?
SteveS
Posted 2013-05-25 11:47 AM (#139521 - in reply to #139519)
Danbury, Connecticut
In the U.S. you can go here NHTSA
XRsteve
Posted 2013-05-25 9:32 PM (#139528 - in reply to #123547)
Mine failed at 22,000 miles. That's why I have 2 spares in the garage right now. Takes 10 minutes to replace.
Boots
Posted 2013-05-25 10:08 PM (#139529 - in reply to #123547)
New Mexico
Mine just failed for a second time - 43k miles. Again, fixed under warranty
MaddMAx2u
Posted 2013-05-26 9:57 AM (#139538 - in reply to #123547)
Orlando, FL
Checking to see if your brake lights work when activated via foot pedal or had lever is part of the safety check BEFORE each ride. Now, I don't know ANYONE that actually does it before each ride but I do it often. Add it to your list and do it. Switches fail.
Monkeyman
Posted 2013-05-26 12:06 PM (#139541 - in reply to #139538)
Peru, IN
MaddMAx2u - 2013-05-26 10:57 AM
Now, I don't know ANYONE that actually does it before each ride...
I do. Turn signals, brake lights, headlights, tires.
MaddMAx2u
Posted 2013-05-26 3:09 PM (#139542 - in reply to #139541)
Orlando, FL
Monkeyman - 2013-05-26 1:06 PM
Kewl~ But then I don't actually KNOW you.
Monkeyman
Posted 2013-05-26 4:26 PM (#139548 - in reply to #123547)
Peru, IN
I'll give you that.
Posted 2013-05-26 5:36 PM (#139550 - in reply to #123547)
Funny how guys can make statements but never read there owners book.
so a break switch failing is different from a taillight bulb failing.
Banjodan
Posted 2013-05-26 8:15 PM (#139556 - in reply to #123547)
thanks for the pre-ride check reminder. I overlook them too often.
Banjodan
Posted 2013-05-26 8:15 PM (#139557 - in reply to #123547)
