Posts: 35 Virginia Beach, VA | Can anyone tell me how to find and where to find the Coil wire? |
Posts: 8144 New Bohemia, VA | http://www.vision-riders.com/bb/forums/thread-view.asp?tid=12496&po...
I thought it was answered here. It's electronic ignition, no need for a coil wire, just the plug wires. |
Posts: 35 Virginia Beach, VA | so if i am installing something that says to use the coil wire....what would i use instead?
Posts: 432 Gettysburg, 2008 Tour Premium | You would use another bike besides the Vision. |
Posts: 432 Gettysburg, 2008 Tour Premium | Sorry for the somewhat smart-ass response. Follow the spark plug wires back to the coil pack. There is no coil wire as in coil and distributor but a wire connector is connected to the coil pack that charges the coils and triggers the discharge. The factory per Lloyd has outfitted the Vision with a MSD system that works up to around 2700 RPM so the ignition is pretty advanced. |
Posts: 466 Grand Cane, LA | If your looking for something that needs a reference for like a tach or something, it is the violet and pink wire that sends the power to the coil packs. The white with the green and the white with the black are the individual grounds per coil side. This is from the wiring diagram for an '08. I'll try to post the pic from the diagram. See if you can see the attachment.
Edited by atvtinker 2012-09-13 9:12 PM
Untitled 1.odg (25KB - 16 downloads)
Posts: 35 Virginia Beach, VA | no worries, made me laugh. |
Posts: 35 Virginia Beach, VA | next question, i had my seat off my 11 vision tour and there is a plug that doesnt appear to plug into anything, is grey colored....any ideas what it is for? |
Posts: 238 SF Bay Area | My guess... trunk wiring or seat heater, assuming the connector is at the back end of the seat. I am guessing.
Edited by buddahead 2012-09-14 12:13 PM
Posts: 466 Grand Cane, LA | If it's the one under the piece in front of the seat, it's an accessory plug. I believe it has power all the time, but don't quote me on that. |
Posts: 35 Virginia Beach, VA | not the trunk or seat they are both plugged in....it is under the front side of the seat.... |
| Use your test meter to see if power comes on with key.
Break down and tell us what your doing. Many of us have been there before you and give you some good information |
