| I noticed today I have a pretty big clunk sound in the front end when I hit a sharp bump. Any ideas what it might be?
Thanks
Steve |
| need fluied or tire is low on air
Not knowing what year bike you have all we can do guess |
| Its an '08
Thanks for the help. I will check it out.
Steve |
| Included signature....
Edited by Udnudn1968 2012-08-18 3:05 PM
Posts: 8144 New Bohemia, VA | Can you hold your bike up to your computer screen and do it again? |
| What is that clunk coming from the front when you hit a bump?
Could it be junk the trunk?
Oh no you didn't hit a skunk, or a hunk of a tree trunk!
It might be a drunk, cyberpunk, chipmunk, from podunk Kennebunk, who likes to do the funk on the bunk, and knocked a chunk from the front that caused the clunk.
Or does it sound like kerplunk?
If that is the case then everything needs to be countersunk, and slathered with gunk.
I hope some punk didn't plunk your hunk, that caused the clunk.
Either way you will need to debunk all the junk that stunk in order to find that clunk.
Goodlunk.
Edited by sgiacci 2012-08-20 12:53 PM
Posts: 2027 Brighton, TN | Tap on the front rotor or caliper with your boot and see if any of it is loose. If you can get it in the air and pull and push on the front end might give you a hint. Push and pull on your handlebars and see if it is loose. |
Posts: 8144 New Bohemia, VA | You ask about the big clunk sound but none of us are around when you made it pound and you're feeling downed we can not be crowned there is nothing to be found if we don't hear the sound nor can we send a hound and we can't see over the computer mound so for now, we are bound to tell you of the sound you found
Edited by varyder 2012-08-20 1:18 PM
