| I wired in a hawg wired speaker&,everything works,the pump cycles and everything but it will not start. Any suggestions Dan |
Posts: 174 Edmonton, AB | Just a thought....Any chance it is fuel level? Could have been enough gas to ride in with the bike upright but gas level too low when trying to start on the side stand.
Had that happen to me once, once I stood the bike upright and primed the pump it started fine.
Edited by Newfie 2012-08-17 1:03 PM
| I had this happen as well. It started just fine when I straddled the bike pulled in the clutch lever. |
Posts: 741 Central New York | More clarity. Does the pump stop after the pressure builds? Does it turn over? |
| the pump does turn over. Everything seems to be normal except for starting. |
Posts: 741 Central New York | I'm sorry, now I wasn't clear. You turn it on and the fuel pump runs; Question, does the pump stop indicating fuel pressure?
Second question; Does the engine turn over and not catch, or does the engine not turn over at all? |
| Everything works as normal except it will not start. The dealer said to try and disconect the amp as installed and see if it would run. NO! Am takeing it to the dealer tommarow. Thanks Dan |
