Posts: 36 coweta ok | just did an oil change for the trip to AVR and thinking I had 5 qts to play with I only had 4 and a little in the 5th, registers just a hair above the first mark, I'm thinking I'm alright to go but get a little anal about this kind of stuff, should be fine, any comments? Marty  |
| I think your alright as well. I do my own oil changes and typically use 4.5 qts with the filter changed as well. |
Posts: 8144 New Bohemia, VA | unless it is extremly hot or ride extremly hard, I think you're okay as well. However, I always have a "taste" of oil around just in case I need to add a little. I figure if I buy 5 quarts every time, I will eventually have a "free" oil change minus the filter. |
Posts: 36 coweta ok | If I had not have changed the filter 4 qts would have been sufficient, but I feel the filter more important than the oil, oh well, I'm going with 4 in it.  |
Posts: 8144 New Bohemia, VA | Happy Motoring!! |
| walmarty - 2012-08-13 12:26 PM If I had not have changed the filter 4 qts would have been sufficient, but I feel the filter more important than the oil, oh well, I'm going with 4 in it.  Get as close to 4 1/2 as you can |
Posts: 457 Green Bay, WI United States | So why is the Polaris oil change kit so many quarts? I just had my oil changed by a home town shop and was kinda freaked out that they only needed 4 liters with a filter change. Comments?
Posts: 23 WI | 4 litres = 4.22 quarts |
Posts: 8144 New Bohemia, VA | 8-ball - 2012-08-13 9:23 PM So why is the Polaris oil change kit so many quarts? I just had my oil changed by a home town shop and was kinda freaked out that they only needed 4 liters with a filter change. Comments? Unless I'm missing something I thought everything was in quarts. Also, you'll find 6 quarts because that was how polaris sold them in the pre-victory days for the ATVs, or so I'm told. |
Posts: 23 WI | some dealers buy their oil in bulk and use a meter to dispense |
Posts: 8 Columbia Co, WI | I use a partial quart to flush 'residue' from the crankcase after I have drained the intial oil. I keep the oil level at the recomended level. |
Posts: 1632 Jasper, MO | varyder - 2012-08-14 8:11 AM
8-ball - 2012-08-13 9:23 PM So why is the Polaris oil change kit so many quarts? I just had my oil changed by a home town shop and was kinda freaked out that they only needed 4 liters with a filter change. Comments? Unless I'm missing something I thought everything was in quarts.? Also, you'll find 6 quarts because that was how polaris sold them in the pre-victory days for the ATVs, or so I'm told.?
The early Victory bikes, like my Sport Cruiser, take six quarts per change, so the kits contain six quarts. The later bikes take 4 1/2 quarts.
Edited by rdbudd 2012-08-14 11:46 AM
