Belt Tension
daveinmaryland
Posted 2012-08-06 9:08 AM (#120997)
Subject: Belt Tension
Lusby, MD
On occasion, seems like when the bike is hot from riding, the bike "squeels" a bit when I release the clutch, in a bigger load situation (two up, or on an incline).
So, using the $60.00 service manual for my 08 VV Tour Premium, I did the belt tension check, and it was right on (1 1/4" +/- 1/16"). However, in reviewing the riders manual, it states that the belt tension, measured the identical way, after break in should be half this number (15/32" +/- 1/64").
Any suggestions? Am I missing something?
marcparnes
Posted 2012-08-06 9:36 AM (#121002 - in reply to #120997)
Subject: Re: Belt Tension
The tension spec was loosened up a couple of years after your owner's manual was printed. It is now 32 mm +/- .5mm (1 1/4" +/- 1/64) with 10 lb force.
Marc
daveinmaryland
Posted 2012-08-06 10:03 AM (#121003 - in reply to #121002)
Lusby, MD
Thanks Marc.
