| I have read where you can remove the baffles from the S1L2 Exhaust pipes. I cannot find a write up on this, so I need a little info on what is involved to do the job. I noticed the screws in the end of both pipes, tried putting a wrench in the allen head but there is some sort of tamperproof deal in the head. I assume you need to pull these bolts to have any chance of removing the baffles. Am I on the right track? Any help will be greatly appreciated.
Thanks
Steve |
Posts: 324 New Orleans, La, | Steve you are correct that the fastener at the end of the pipe must be removed. The fastener is a tamper proof torx fastener and you will need that type of bit to remove them. Once thats' done it is straight forward from there. No rocket science or anything. |
| V92SC - 2012-07-26 9:20 PM
Very Cool! Guess I will have to find a tamper proof Torx fastener bit that will fit. Maybe Harbor freight? Do they just pull out the end then? Thats all that holds it?
Thanks for the help!
Steve |
| My S1L2 pipes have an allen head bolt with the center raised so you can't seat a wrench. |
Posts: 324 New Orleans, La, | It may be possible some S1L2 pipes came with tamper proof Allen bolts securing the baffle, but mine came with T25 tamper proof torx fasteners. I speak from experience bought the bit from HF took the baffles out and decided I rather them in fornow. |
| V92SC - 2012-07-28 12:05 PM It may be possible some S1L2 pipes came with tamper proof Allen bolts securing the baffle, but mine came with T25 tamper proof torx fasteners. I speak from experience bought the bit from HF took the baffles out and decided I rather them in fornow. I'll check harbor freight, thanks |
I couldnt get a wrench to fit, so I polished em up and am sending in for the Atom Bomb mod.
Thanks for the advise guys.
Steve |
