Posts: 27 Lusby, MD | I did a quick search, and didn't find anything that seemed like this issue, so, if I have missed something, let me have it!!!
I finished a 1200+ mile, four day ride, and on the way home with my group, when we stopped for fuel I first noticed this.
As I would walk the bike up to the pump, or away from the pump, with the engine off, I would hear the slightest pop, and feel it at the same time. Nothing loud enough for bystanders to take notice, but on the bike, it was something I did. No issues at speeds up to 80mph, and would like to prevent any future issues.
I got home late last night, so I did not get any time to look into this.
At this time, it seems to happen at the same point in rotation of the front wheel, but, have not proven this yet.
Could this be just a brake rub? Or is it probably a front wheel bearing starting to go bad?
Any help would be appreciated!
Posts: 8144 New Bohemia, VA | First of all, why would you ride it when it concerns you? Second of all, no one here has a crystal ball. Please put it up on a lift and have someone who knows what to look for check it out. |
Posts: 206 Lumber Bridge, NC United States | go to the front fender and wiggle the back portion I would guess that it has cracked. I heard the same thing and it was that the left side of the fender was cracked at the bolt hole. (but I could be wrong.) |
Posts: 2027 Brighton, TN | vacantankerousryder - Have you gone off your meds, you seem to be getting a little more testy than usual.
daveinmaryland - remember varyder is looking out for your safety and he has good points, but hasn't had his coffee yet.
The rotors could be loose or warped.
The bearing could be wearing out not likely, it would be notchy all the way around most likely.
Could be the belt on the pulley. Mine makes some noise in the same spot occassionally. |
Posts: 8144 New Bohemia, VA | Maybe something simple, maybe not. But riding at 80 mph is a heck of a way to find what is really wrong. Or asking folks to guess with your life. Two cups of coffee already, but this post did not make my day. Gee, what was that...? You should have some Vicsters close by or you could take it to White Plains to have it checked out if you're not sure what to look for. If I sound sharp, should I apologize? I have a friend who went down when his bike lost a front wheel bearing at 60 mph on the interstate, spent 6 months in rehap and has a back that looks like an orange peel, but would have been worse without his leathers. Oh, and just recently, didn't someone post about the last thing they remember they were in a turn and then felt a wobble...and was told later they went head on into a car. We have enough against, I don't need to help things along...
Edited by varyder 2012-07-23 9:38 AM
Posts: 1308 Sand Rock, AL United States | If you take Chris the right way, it's caring, concern and urgency. I think He's a tough love kinda guy  |
You can hear it? And you can feel it?
What the hell are you trying to say? |
Posts: 27 Lusby, MD | Thanks for the valued input, it has been a very busy week at work, and have yet to touch the bike.
The bike is a 2008 VV Tour.
I hope to get some time this weekend to work on the bike.
Again, thanks for the input. |
Posts: 161 Albuquerque NM | Start simple, first see if you can get it to repeat. If you can, have someone mark what part of the tire is down when it makes the noise, you then have a place to begin inspecting.
If you can't it was probably a pebble that stayed in the tread, and left again before you even got to 20mph.
Check for any play in your wheel bearings. Also verify that your rotor doesn't have any knicks or gouges that could be vibrating the caliper.
BTW how many miles does your bike have on it?
How old is your front tire?
There's a lot of important pieces in the front end of our motorcycles, and while they may be simple our lives depend on them functioning properly. If the answer doesn't present itself readily, have a pro take a look at it. I don't want to read about another rider going down for a long time. |
Posts: 27 Lusby, MD | I finally got a bit of time to start some troubleshooting. The bike does it just rolling forward in the garage, so, being alone, I put it on the lift, and turned the front wheel slowly, listening, feeling, looking.
The front wheel right side disk is warped, you can slowly turn the wheel, and for the most part, no noise, no nothing, then, you can hear disk drag, and then, you can hear (and eventually, once I got my fingers in place) feel the right side caliper slowly deflect to the left, then the caliper suddenly move to the right. Continuing, you can do the same, and observe it. I need to get a run out gage and see how bad it is, and then probably replace both disks.
BTW, the bike is new to me last December, has 22k miles on it, brand new tire, and according to the dealer, the brakes were done before I looked at it.
I will be reviewing the shop manual, and getting some mic readings when I replace the disks.
Thanks to everyone for their support.
Anyone got a source for brake parts that they can recommend. |
Posts: 3773 Pittsburgh, PA | @ daveinmaryland may i ask where you bought the bike from? |
Posts: 249 Phenix City AL. | Something to think about, the rotors as floating rotors, the rivets that hold the inner part of the rotor to the outside of the rotor should spin, or move. Dirt or break dust can build up in the rivet and not let the rotor float. Try moving the rivets around, if they are stuck, use your brand of cleaner, soak the rivets, then cover the rotor with a towel and tap the rivets with a rubber hammer, of course it would be best with the rotor taken off the wheel, but you could get it done while it is still attached to the wheel, remember a firm tap, you do not Jabber beat it with all you can give it. I would try that before looking for new rotors. |
Posts: 27 Lusby, MD | Arkainzeye:
I purchased the bike near Pittsburgh, PA. I don't know the original owner.
Edited by daveinmaryland 2012-07-28 11:00 AM
Posts: 27 Lusby, MD | jb.hatch-
What type of cleaner would your suggest? A brake cleaner?
I did got out and just turned a few of the rivets, they do turn, but, I would do the cleaning part first, before tackling the rotor replacement.
Thanks jb. |
Posts: 3773 Pittsburgh, PA | daveinmaryland - 2012-07-28 10:54 AM
Arkainzeye:
Did you get it from a dealer called snow? |
Posts: 249 Phenix City AL. | I would use WD 40 or PB blaster, break cleaner might take the paint off the rotors, I am not an expert but that's what I would try. |
Posts: 27 Lusby, MD | Did you get it from a dealer called snow?
Yes, why, is it your bike? |
Posts: 3773 Pittsburgh, PA | Its my bike if it was silver, came with a back rest and the speedometer doesnt match the actual mileage. (Speedo was replaced under warranty) |
Posts: 27 Lusby, MD | BINGO! |
Posts: 3773 Pittsburgh, PA | Holy crap! Small world. I have a ton of photo of that bike... btw brake pads were replaced with ebc pads. There is a new rear rotor and all brake and clutch fluid were flushed.... |
Posts: 27 Lusby, MD | I PM'd you. |
| There was a guy that tuck a bolt looked like a 1/4x20 and put washer on the size of the floater button and slide the bolt threw the hole and then slid a washer on the bolt and then a nut and tightened the bolt that re crushed the rotter button.
If you do a search you can find rotter floater buttons. Drill out a button measure it and look for them do all of them on the rotter not just one. |
Posts: 249 Phenix City AL. | Its my understanding is you want the rivets loose, so that the rotor floats, I learned that when I thought I had bad rotors on my TC, I did what I was told, , free up the rivets by soaking them with a cleaner, and giving them a tap to get the crud loose. I Worked on my TC. |
Posts: 8144 New Bohemia, VA | jb.hatch - 2012-07-28 9:34 PM Its my understanding is you want the rivets loose, so that the rotor floats, I learned that when I thought I had bad rotors on my TC, I did what I was told, , free up the rivets by soaking them with a cleaner, and giving them a tap to get the crud loose. I Worked on my TC. I don't think you want this though... |
| varyder - 2012-07-28 9:06 PM jb.hatch - 2012-07-28 9:34 PM Its my understanding is you want the rivets loose, so that the rotor floats, I learned that when I thought I had bad rotors on my TC, I did what I was told, , free up the rivets by soaking them with a cleaner, and giving them a tap to get the crud loose. I Worked on my TC. I don't think you want this though... How did you fix it? Rotor buttons or new roter? |
Posts: 8144 New Bohemia, VA | johnnyvision - 2012-07-29 1:53 PM varyder - 2012-07-28 9:06 PM jb.hatch - 2012-07-28 9:34 PM Its my understanding is you want the rivets loose, so that the rotor floats, I learned that when I thought I had bad rotors on my TC, I did what I was told, , free up the rivets by soaking them with a cleaner, and giving them a tap to get the crud loose. I Worked on my TC. I don't think you want this though... How did you fix it? Rotor buttons or new roter? New rotor, under warranty.
Edited by varyder 2012-07-29 1:53 PM
Posts: 45 Ventura County, CA | I don't want to take this off topic, but I have a problem that could be related to this. I just had my bike painted and had the lower parts of the rotor painted as well. The other day I lost a front top caliper bolt. Just fell out on a ride. Talk about a shaky, wet your pants ride back home! The best part now is trying to find a metric fine thread bolt. No Polaris or Vision dealers in a 100 mile radius have the bolt and claim it will take weeks to get. I was able to find a place out here that specializes in Metric bolts. They claim to have them machined for them out of stainless, so I will be picking them up this afternoon. The point is, my rotor DOES NOT float. Could this have been what loosened up all of my caliper bolts? When I put the bike back together, I lock tighted each bolt and torqued to the proper range. The other three were loose, but not loose enough to come out like the first one. BTW, if you here a clunking sound in the front end when hitting bumps, could be a loose caliper as well. |
| Hardware stores carry metric bolts.
Floating rotors really don't move but more then a mm. When you apply the breaks the caliper centers its self between the break pads.
Your rotors are more then likely just fine
Posts: 27 Lusby, MD | I wanted to follow up on this post. I did some work on the bike this weekend, and using a dial indicator on the front rotors, the front right rotor is 0.068 out of true, and the left is 0.003 (pretty close to perfect). The 0.068 deflection rises slowly, but drops quickly, coinciding with the rapid shifting of the caliper.
New rotor is on order.
Thank you to everyone that responded, I appreciate it. |
Posts: 8144 New Bohemia, VA | Glad you found the culprit. I'm curious as to possible damage during a tire change like dropping it hard. Or, is there any signs of bluing from heat build-up. One last question, where's the best seafood in your area? |
Posts: 27 Lusby, MD | There is no bluing, but, will take a better look once I have it off, spiffy paperweight at that point.
Best seafood, mmmmmm, are you visiting the area?
Opinions vary, a restaurant in Broomes Island, called Stoneys has long been the legendary king of the crabcake. They now own about four restaurants in the Calvert County area. A couple of their locations have great water views.
Newer entry in the category is a small place called Jerry's, just south of Prince Frederick on the South Bound lanes of route 4. Everyone that goes to Jerry's just really raves about it. The place is not much to look at, the end unit next to a multi bay tire dealer, but the atmosphere is raved about. (My wife and gf ate there two weeks ago and loved it)
If you have a specific area you are riding to/through, I can inquire.
I have an email into a friend that had a recommendation in the Annapolis area, I believe the restaurant was named, Edgewater Restaurant in Mayo, MD.
(BTW - can't personally recommend any of them, I don't really care for seafood, but, EVERYONE else in the area recommends these places. |
Posts: 8144 New Bohemia, VA | Thanks Dave. I roll that way every now and again. I'd like to take my wife up that way for an overnighter, or a long day trip, long for her anyways. I'm curious, but did you, the wife and gf ate a Jerry's together, or at seperate occassions???
Edited by varyder 2012-08-07 9:04 AM
