Radio Dies
conny.martinsson
Posted 2008-06-20 8:30 PM (#12156)
Subject: Radio Dies
SO CAL
The Radio died this morning on my way to work. Basically the song from the Ipod were still showing on the display even when the ignition key was turned off. If this happens to someone else the fix was pretty simple after reading the manual that came with the bike.
The FIX is to remove the fuse and then reinsert it gain.
To do this simple job you have to remove the aluminum panel. This is done by pulling each side straight up (watch for the tabs in the bottom). When removed you will see the fuse box on the right hand side. Remove the panel above it by pushing out the center pins in the plastic plugs. Then the fuse ox has a latch on each side that has to be pushed.
Remove the fuse with the fuse puller and put it back again, the ignition switch shall still be put to off.
Turn the key to acc and the radio should come right back.
Now just re assemble the bike again following above instruction in reversed order.
Hope this will help someone
Conny - Out
