| On way home from trip 2 weeks ago, my cruise went out, on/off button will not come on.
About 20 miles or so later, the blinkers and brake lights go out.
I'm thinking it is a fuse or relay, but everyone is telling me they think it is the battery.
I located the battery and got positive and negative unhooked, as well as the bolt directly above the center of the battery, but I can't get the battery out.
Some trick I am missing?
I just got this bike about a month ago and love it, trying to figure it out, not the most mechanically of people, but want to learn to work on it.
Any advice is appreciated.
Thanks |
Posts: 8144 New Bohemia, VA | As far as I know, move that top hold up and tilt the battery out. |
| Sorry, didn't realize I posted this twice.
I got the terminals on the battery cleaned and reconnected and that did not fix the issue.
I checked the fuses and relays in the fuse box, and all seem to be good from what I mied around.
Does anyone know which relay or fuse is the one that controls the blinders/brakes lights, or the cruise?
Posts: 8144 New Bohemia, VA | Check your fuse panel under the front cowl. It is marked, plus it is in the owners manual. I don't know right off. |
| Not knowing what year it is?
Look in your owners manual and it will tell you where the bolts are and hot to get at the fuzz panel |
| I figured out how to get to the fuse panel and how to get to the fuses.
There is no label that says cruise or one for blinkers. |
