Posts: 5 broadalbin new york | HOW MANNY MILES HAVE PEOPLE GOTTEN ON THESE MACHINES SO FAR AND WHAT ARE THE COMMON PROBLEMS? |
Posts: 164 Quad Cities, IL | I just rolled 32k on my '08 Vision. That's peanuts compared to some here on the forum, with at least one over 100k. Other than routine, the only major replacement was the Stator, I noticed it was going bad before it left me stranded and warranty covered it so it was no big deal for me. Nothing else major that I would consider a problem. Love the Vision!!!  |
Posts: 1290 Ruskin, Fl | I had 35,000 on my first Vision I bought new 5/2008. Only problem was the MAP sensor went bad the first week and the battery went bad in less than a year. Dealer took care of both right away. Totaled that on 1/8/2011. I replaced it with a used 2008 with 18K on it. I just passed 45,000 on Vision number 2. Only problems was the battery took a dump on this one too and the throttle body adaptor needed to be replaced. That was an 08 issue and was covered under extended warranty. |
Posts: 752 Broken Arrow, OK | 2011 I've had for 10 mo's, 10K miles, no problems. I did see your post about the tranny clunk. Yes, I have that but I guess it's gotten used to me. |
| My 08 has 34K and my 09 has 11K both in the last 2 years. No major problems. Good luck with your new Vision! |
Posts: 2118 Pitt Meadows, BC Canada | Gordy, welcome to the Club of owners of the best bike on the Planet.
Best advice I can give you is - learn how the 'SEARCH' function works. Any questions you might have can be answered in older posts and discussions.
Then if you STILL have a question - ASK ! ... but do some research first. We are an 'experienced' bunch with the minor problems we have had. Me? Nothing that hasn't been handled by my dealer - under warranty - and VERY little of that !!!
Posts: 523 seattle, wa | 22k on my 08 and the rear shock went bad, other than that I have had no other problems. I have heard of a few rear shocks going bad. $500.00 replacement cost. |
Posts: 367 Cottage Grove, Mn | 40,000 miles; Oil changes, brakes and tires. Float replacement.
Edited by Blackjack 2012-07-01 6:27 AM
Posts: 103 Duanesburg N.Y. | only have 7,800miles on my 09 vision with no issues with it other than when it jumped off my bike lift last summer and tried to commit visioncyde, and my mileage i'm embarrassed to say is nothing in the vision world. A gentleman in my victory club bought a vision last summer and has over 18,000 miles at the last meeting and has no issues with it.
Eric |
Posts: 324 New Orleans, La, | I have 55K on mine it has had the following problems, replaced the fuel pump once and radio twice under warranty, battery under warranty, 2 front fenders that cracked at the bolt holes, 2 front wheeis my fault of course, and numerous tyres and oil changes. It is an 08 Tour Premium. Withh that it is still the bset touring rig out there bar none. JMHO. |
| 10 months on my 2011, 25,000 miles.... |
Posts: 499 Chattanooga, TN | 32k on my '08VV. Had it since spring 2010. Love it, maintenance items only, no problems, just upgrades! |
Posts: 102 Jal NM | I've had my vision for 8mo got 5320 miles no problems just regular service. Oh I forgot to say 2011 vision.
Edited by SkooterRob 2012-07-01 2:21 PM
Posts: 849 , FL United States | First year Vision - a couple of things taken care of by warranty - fuel pump and throttle body adapter
 (0630021349.jpg)
Posts: 374 Tucson, AZ | 08 Vision with 84K, had rear shock replace under warranty, fixed broken rear part of front fender, lots of oil changes, and lots of smiles....
mike |
Posts: 599 New Mexico | 09 Vision with 33k. Have had problem with cruise control - twice. First was front brake switch, and now appears to be cruise control module. Both repairs under warranty. Other than that, not a single problem.
Edited by Boots 2012-07-01 6:16 PM
Posts: 53 Gotha, FL | 1 year on my 2011 and 21,000 miles and nothing has gone wrong. Everything works as expected. |
| If you look at all the post here you'll find very few have had any problems. The ones they have had are miner ones. Batterys you can't count cause no one knows how long they have been sitting before going into a bike.
The worst problem of them all and we all have it is the poor radio reception the Vision has. Guess its just a bad antenna but no one want to have a pole sticking out of a beautiful design bike |
| 2011 with 35,000. Only problems have been a failed regulator at 1500 miles and a crack in the rear part of the front fender. Both fixed under warranty.
Marc |
Posts: 259 Land O Lakes, FL | 6200 on mine in 3 months and so far so good.... |
Posts: 1308 Sand Rock, AL United States | there are 2 Visions I know of with 100K on them. I have 23,500 on mine, I have done nothing to it but ride it, but I just bought it 5 weeks ago and put only 3500 miles on it.  |
Posts: 1308 Sand Rock, AL United States | mine is a 2008 by the way. |
Posts: 133 , AR United States | I have a 2009 Vision with about 26,000 miles now that I bought in April 2010. I consider it a great bike. I have had issues that were taken care of under the (5 yr) warranty.
1) The radio failed, I had display but no sound. They upgraded the software, then replaced the radio. Very soon that one would lose power and go off and on at random. They replaced it and this one has worked fine ever since. I have heard of radio issues from other riders, so this may be a common problem with the 08's and 09's.
2) It developed an oil 'seep' at the bottom of the front cylinder. The mech said it was a seep not a leak because it was so little oil. It never actually dripped off the bke. Porous castings was to blame, they replaced most of the engine before this went away. I had to break it in all over at about 8,000 miles. I have read one post where another rider had this, so I consider it a RARE problem, again with 08's and 09's.
3) Oil coming from front injector area. Not a lot of oil, but it ran down the cylinder. They replaced the valve cover gasket, then the valve cover, then found a bad seal or o-ring at the injector or near it. Not sure how that works, does the injector seal hold back oil? I suspect this seal was damaged when the engine was put back together before. So I don't think this is common, just human error.
4) The plastic belly pan under the battery split in half. I don't know why it broke, but they replaced it. I have never heard of any one elses breaking, so I put this in the rare category.
Once the pivot screw in my clutch lever siezed. I thought my clutch was going out until I pushed the lever forward. I took the nut off the screw to let it move freely, but I couldn't break the screw loose with my chinsy screwdriver. I took it back to the dealer and they cleaned it up and put some antiseize in it and the nut back on. Not much of an issue but I thought it worth mentioning.
Occasional popping, backfiring. I have heard this is caused by closed loop fuel injection. It is more noticable with loud exhaust. Lloyd's idle air valve helps this. I had Thrush mufflers on my bike for most of 2011. I went back to the stock mufflers last fall, but still use the iav and don't hear any popping now.
Anything made by humans can break, but I beleive Victories are among the best made motorcycles. |
| I have a 2008 Vision tour with 30,000 miles that I bought new.
1 The first week the stater failed but the mechanic replaced the wiring harness. When I went to pick up the bike a week later the bike still would hardly roll over. The red faced mechanic then stated it needed a starter. Another week later it was complete.
2 At about 15,000 miles replaced sprockets and belt under warranty to stop belt squealing. 15,000 miles later it is back.
3 Recently the rear shock is loosing air after a week. The bottom of the shock is covered with oil indicating a leak. I went to my local dealer and the service person stated without looking up "shocks are not covered." We have submitted shocks on snowmobiles and Polaris does not cover shocks. This is the same service adviser that when I had a rattle and asked if the mechanic could take it for a spin told me it would be 1hr labour at $99.00
4 Bought bike with stage one but the popping drove me crazy so I have re installed the stock exhaust.
5 I had my first rear tire replaced by my local dealer at the cost of $550. I have since taken off my own wheels and another bike shop gives me 15% off plus free install the tires on the rims. I currently running Bridgestones and so far happy with them.
Would I buy another vision?
I like the ride and performance. Love the electric windshield and the seating position especially on long trips. Probably will in a few more years as living way up north can only ride 5 to 6 months a year.
Edited by boatsrfun 2012-07-02 1:06 PM
Posts: 1229 Rancho Cucamonga, CA | 27,000 miles and most everyting I've had to replace were because of my own errors. New front fender, because I put too big a tire on. New battery, because I listen to the radio too much with the bike not running, New headlamps, because I thought the Anti-Vib ones would work better. The only thing I can blame -Ma Vic- for, is the LED in the lighted badge stopped working. My dealer is working on getting it replaced under warranty as we speak. |
Posts: 130 Houston, Tx | 2010 Vision and only problem outside of $$$ for gas, oil and tires is my rear air shock. Dealer is currently trying to get one in to replace under warranty.
As for mileage, check out fellow Houston BCVR member: http://www.victorymotorcycles.com/en-us/Experience/Pages/LonnieD100... |
| 2009 Anny with 83,000.
Bad run on wiring harness. Broken rear pulley. A few other things. I am the guy with the bad luck so others don't have them.  |
Posts: 1365 Central Maryland | RedRider - 2015-07-29 6:03 AM
2009 Anny with 83,000. Bad run on wiring harness. Broken rear pulley. A few other things. I am the guy with the bad luck so others don't have them.
Not True. Just found my front drive sprocket seal is leaking AGAIN; after the Vic dealer "fixed it" one year ago.
I am so pissed off right now.
I may trade it in for a Honda F6B. I want reliability. The Vision is not providing that.
Posts: 1308 Sand Rock, AL United States | UPDATE:
2008 with over 115,000 miles on it. Only thing I have done to it is blow a headgasket at around 91K miles. My own mistake. I let it run in 4th of July Pigeon Forge stand still traffic for EVER and it developed a smoking issue on cold starts, I rode it this way for about 2,000 miles but it got progressively worse so I put it in the shop and had the issue addressed. I have also replaced my heated grips as my throttle side didn't work. My trunk retainer cable recently broke and the trunk light stopped working (not a bulb issue). My stock seat ripped at the seams as most early seats did. My headlights are flickering sometimes as of this morning. I just noticed this issue today, center beam is solid but support lighting is intermittent. Those are the only issues in 115,000 + miles. I just put tires , brake pads and change oil and an occasional light bulb. I'm on the original belt, original front fender, original fuel pump. original shocks.
Edited by jimtom 2015-07-29 8:51 AM
| jimtom - 2015-07-29 9:48 AM
UPDATE:
I love reading posts like this about the 08 and it's bullet proof reliability. Thanks |
Posts: 573 Central Illinois | Only 21700 on my Vision so far. I lost a starter clutch at about 15000 miles but nothing else before or since. The charge would have been about $200 but I was still under warranty at the time so no charge. |
