| Hey Everyone,
I just bought one of the discontinued Victory Passenger Backrests for the Vision. It has everything except for the template to cut the rear panel. Does anyone have one they can scan and email me or xerox it maybe? Any suggestions would be appreciated.
Many thanks and ride safe,
Jim |
| Look on youtube for some maybe ideas |
Posts: 965 New York State | Trace the filler plate then cut it to fit backrest its only paper may take a few tries . |
| Turns out the template is already embossed on the back of the cover. Doh!
Jim  |
Posts: 104 ROCHESTER,NY | That's what I was going to say. But now the big question, How do you make these cuts with out, burning or chipping the paint?????? |
| A used hacksaw blade would work And blade that is used cause it wouldn't have sharp edges to grab what you don't want to.
Do practice cuts in the middle where it doesn't matter. Wrap some tape around the blade and use that area as a handle |
Posts: 1229 Rancho Cucamonga, CA | I covered the painted part with masking tape, the cut with a hacksaw with about 1/16"play that I then used a Dremmel to smooth it all out. Then took off the tape. BTW, the template on the back of the coverplate is not perfect. You may have to expand it a little, so give yourself some fudge room. |
| pull back the velcro on the back rest. its up there |
