Tool Kit/Rear Shock Air Guage
opas ride
Posted 2012-04-05 12:45 PM (#111545)
Subject: Tool Kit/Rear Shock Air Guage
I give up!! If I did get a tool kit with my 2011 Vision where is it located??? Also, does a regular pencil tire guage work okay to check rear shock pressures??? I had a hell of a time trying to adjust the pressure...I ordered the Victory pressure guage/pump yesterday from dealer to, hopefully, make it easier to adjust....Thanks
Posted 2012-04-05 12:58 PM (#111547 - in reply to #111545)
Subject: Re: Tool Kit/Rear Shock Air Guage
Should be in saddle bag. Its a joke and if you do find it the air gauge is junk. Go to the auto store and buy a good gage it will pay for its self. Not sure what air pump you ordered but if its what I think a little hand pump its good for air shock. For tire you need a compressor but you don't need a big one.
You don't say where you live but check your tires once a month. 40psi rear and 38psi in the front. You will get longer life out of them this way. I just ordered a new front tire and I have 18 thousand on it.
marcparnes
Posted 2012-04-05 1:15 PM (#111552 - in reply to #111545)
You can pick up the same shock pump from a Harley or bicycle dealer. The cost I believe is about the same. Just get one with the proper range gauge. The max you'll use for the shock is 75 psi so try to find one that has a max reading as close as possible so it will be easier to read at lower pressures. The one I have goes up to 120 psi.
Marc
opas ride
Posted 2012-04-05 3:46 PM (#111560 - in reply to #111545)
Thanks for the replies...I quess I did not get a tool kit as I cannot find it...No biggie as said, most are junk anyhow....I live in the Detroit area, thank God not in the city, I do try to keep tire pressures at 38/39 front and 40/41 rear....Rear shock at 20psi according to my weight and the manual info.......The pump/guage I ordered from Vic is the part # listed in the manual so I assume it will work okay......
Posted 2012-04-05 3:56 PM (#111561 - in reply to #111545)
The vic tool kit is a joke.. so if you cant find it, you arent missing anything... i bought an HD air pump from my local HD dealer IN STOCK forn around $20-$25
SkooterRob
Posted 2012-04-05 6:45 PM (#111567 - in reply to #111545)
Jal NM
Just ask your dealer for the tool kit if they don't have it they should get you one free of charge, and yes I know people say they are junk but you bought the bike and it is supposted to have one. I think you should get everything you paid for.
Posted 2012-04-09 12:17 PM (#111782 - in reply to #111545)
My toolkit was hiding inside the owners manual case. It's basically a couple allen wrenches.
opas ride
Posted 2012-04-09 6:30 PM (#111809 - in reply to #111545)
Sorry for the late response...Found the tool kit and it is piece of junk....But I bought the Victory pump/guage unit at the dealer and it solved my problem with ease.....Thanks...
goat813
Posted 2012-04-10 8:12 AM (#111854 - in reply to #111545)
W'ford Tx
There's a case for the owners manual?!?!?!?
ghostssx
Posted 2012-04-10 9:08 PM (#111924 - in reply to #111545)
Bluff Park, Alabama - God's Country! 2011 PW VV
Yeah! On the 2011, they give you the small case, even though the manual is now much bigger! LOL.
