| About two months ago I pulled off the center console, the wire looked different so I thought it would be easy to put back together. Well I quess they are not all the same. Anyone know how to hook them back up. Thanks |
| I have the console off my 2011 8Ball right now. It's bare bones compared to the fully loaded models. What do you have? |
| Sorry, it's an 08 Vision |
Fountain Inn, SC United States | Removing the center console requires you to disconnect a ring terminal that acts as a ground. Unless you disconnect/removed the radio and the accessory rocker switches, there shouldn't be any loose wires except for a pair that is used for an optional power outlet right in front of the seat. If you've disconnected the rocker switches, you'll probably need to refer to a wiring schematic to reconnect the right wires to the switches. In that case, look on our Links page for the link to the service manual section you need.
| I pulled my console off last week to paint it so I disconnected all the rockers. There's a link to a wiring diagram on the links page complete with pictures. I don't remember what the link is but it's there. |
| Iowan
here the heated switch get a brown on one end a baby blue on the end with a white connector in the middle. The 4 way is a black connector with two wires. The HID is a white connector with three wires. The radio I think you know is a multi wire plug in. |
| got it thanks for all the help Dan |
