Posts: 241 Monrovia, Ca | Will the Vision CB system allow you to make and receive calls form an I phone hooked up to the proper connector?
Thanks |
Posts: 155 Stockton, California | I could be wrong but I do not believe so. They only way I have done so is by bluetoothing my phone to my Zumo 660 GPS (which is connected to the CB/intercom system). The phone goes in the pocket. Then you can make and receive calls using the Zumo by voice command |
Posts: 241 Monrovia, Ca | Yes I know it can be done with blue tooth,I have Scala g-4's now.
How did the rack turn out? |
Posts: 74 Republic of Texas | I have the G4 Powerset. Using an Android Atrix phone, it connects directly to the G4 via Bluetooth. No Problem.
I use the Phone for MP3 tunes, Google Maps and Google Navigation in place of a GPS. Of course the phone works fine too.
The phone does respond to some voice commands. Just not very well.
I am bypassing the bike's radio.
And, I suppose an Iphone will work equally well.
Edited by Wharf_rat 2012-03-02 8:34 PM
LA Victory Rider - 2012-03-02 5:39 PM Yes I know it can be done with blue tooth,I have Scala g-4's now. How did the rack turn out? The rack turned out great. The local chrome guy did a nice job. Here is a pic.
 (Rack.jpg)
Posts: 130 Houston, Tx | BreadmanRo - 2012-03-02 6:49 PM I could be wrong but I do not believe so. They only way I have done so is by bluetoothing my phone to my Zumo 660 GPS (which is connected to the CB/intercom system). The phone goes in the pocket. Then you can make and receive calls using the Zumo by voice command So, how did you connect the Zumo to the CB/Comm wiring? I'm assuming you hard wired into that system vs using the Vic plug? I'd like to know more about this. |
Posts: 155 Stockton, California | Blu, There is a audio integration harness that you have to buy to connect the GPS to the cb/intercom. (part #2877930) |
