Headlight replacemet
TRELL
Posted 2012-02-08 2:00 PM (#107234)
Subject: Headlight replacemet
Dealer called said headlight was in bring bike in on tuesday 2/7 well when he went to put the new assembly in
it was worse than the old one.Now got to wait until a new one come in.I would think to check the part before tearing bike down.But I like my dealer they are good to me.CORBIN MOTORSPORTS Corbin Kentucky.
Posted 2012-02-08 5:36 PM (#107250 - in reply to #107234)
Subject: Re: Headlight replacemet
Worse than the old one? What did they do, send you a used one?
Posted 2012-02-08 5:57 PM (#107251 - in reply to #107234)
I'm guessing you have a crack light. If so ask them to check to see if the mount the light is bolted to is flat. Have them run a straight edge all over it.
Good luck
TRELL
Posted 2012-02-08 7:08 PM (#107257 - in reply to #107234)
getting water in light, they said that the new one had the corners broke.
Lojak
Posted 2012-02-08 7:28 PM (#107258 - in reply to #107257)
New Brunswick , Canada
TRELL - 2012-02-08 9:08 PM
Listen to John Frey...this is something i'll have them do..Cause i'm on my 3rd broken headlight on my 2010 Vision.
Every one of them crack at same place as yours...No problem getting them change on warranty but they are not looking to find or solved the problem. So what going to happen when the warranty runs out.. $$$$. just whish that Victory would step up at the plate and find a solution. For now everybody's hiding there head in the sand..
Don't get me wrong, i love to ride this bike , just need a solution to fix this...
