heated grips problem
adolfoch
Posted 2012-02-05 1:07 PM (#106938)
Subject: heated grips problem
CARTAGENA Spain
Hi all, I have a vision of 2008 and the heated grips heat up very little, buy new ones thinking that the problem was with his fists but still the same and the connections are good, someone has had this same problem
Posted 2012-02-05 3:11 PM (#106949 - in reply to #106938)
Subject: RE: heated grips problem
adolfoch - 2012-02-05 2:07 PM Hi all, I have a vision of 2008 and the heated grips heat up very little, buy new ones thinking that the problem was with his fists but still the same and the connections are good, someone has had this same problem
I've never had the grips get very hot, ever.  In the very cold, they seem to have no value, and I'm talking about 30 degrees f.
adolfoch
Posted 2012-02-05 4:19 PM (#106952 - in reply to #106938)
Subject: Re: heated grips problem
CARTAGENA Spain
thanks varyder, here the temperature is 3 ? C and heating of fists is too low and virtually no heat, I'm thinking of buying gloves heated, I bought my previous bike a kawasaki nomad 1500 about heated grips and the heat was much higher those who mounted the victory vision series
Posted 2012-02-05 4:36 PM (#106956 - in reply to #106938)
I believe that the Victory Vision will take aftermarket heated grips, but you should make sure before you buy. Heated gloves may be good. But at 3 degree C you should be okay. Maybe they are defective. Do you have a dealer?
